I know there are a number of the forks from the lower end of the manufacturer range but who makes a decent higher end fork?
80/100mm travel.
new or second hand?
Ideally new but open to suggestions.
Ideally I need a 210mm steerer so I guess that further reduces the market.
You may need to look for "new / old" stock (think they were v compatible up to 2010?) but would Recon Races suit?:
EDIT .link removed as it was to wrong fork!
Failing that if you just want something second hand which works decently I've got a set of pre Taiwan MX Comp Airs with uncut steerer and V brake bosses which will be going into the classifieds shortly!
Are [url= http://www.on-one.co.uk/i/q/FORSRES80/rockshox_recon_silver_tk_coil_80mm_fork_without_poplock ]these[/url] too cheap ?
Old SIDs?
