Decathlon hydration...
[Closed] Decathlon hydration bladders?
[#9392231]
Worth a punt of better sticking with a camel bak or osprey?
whaddya think?
Posted : 20/06/2017 10:14 pm
They work fine. Not as fancy as the camelbak with quick release and angled brute valve but you don't really need any of that.
Posted : 20/06/2017 10:16 pm
They're about the o lay thing from Decathlon I don't rate, albeit I haven't bought one for a while.
I'd like to know myself.
I left my Osprey full of squash for 3 weeks by mistake, more cultures than the Louvre when I found it.
Posted : 20/06/2017 10:18 pm
Bags are good, mixed reports on the bladder but they will stand by their two year guarantee.
Posted : 20/06/2017 10:19 pm
Posted : 20/06/2017 10:20 pm
My kids have the bags and bladders. Great for the price. I like the whole end of bladder opening, it makes it easier to dry completely, but you can't remove the tube to dry that properly.
It's fine to be honest.
Posted : 20/06/2017 10:23 pm
They're fine and do the job well enough, but nowhere near the quality of an Osprey. After a fair bit of use mine developed a constant drip, fine in the summer, but started to get a bit cold having a wet leg in the winter.
Jnr bit the end off one of his once, he was being heavy handed, but I wouldn't expect that with an Osprey.
Posted : 20/06/2017 10:31 pm
nickjb - Member
POSTED 11 MINUTES AGO # REPORT-POST
I'm assuming 'brute valve' is a typo, but it is a fair discription of mine.
The on/off valve is either leaking onto my leg or impossible to get liquid out of. Sometimes it's easier to remove the valve and drink from the tube.
Posted : 20/06/2017 10:33 pm
 FOG
Actual bladder is fine but the bite valve is a bit rubbish. I tried to graft an Osprey valve on but the actual tube sizes are incompatible . I'm sure somebody more technically able than me could sort it but is it worth it for the price difference ?
Posted : 20/06/2017 10:34 pm
My lad is using one on his DofE expeditions, no problem so far.
Posted : 20/06/2017 10:38 pm
 poah
No complaints from my son with his.
Posted : 21/06/2017 3:33 am
 tomd
I've got one that I've been using for a while. Bought it probably end of 2015.
It's OK. The bag itself I cannot fault and a prefer the top opening system to the camelbak - it's easier to fill and clean. I didn't get on with the mouth bit - it always seemed to leak a bit and it got worse with use. I swapped it for an old camelbak one I had. They may have improved it.
Value for money wise they're pretty good.
Posted : 21/06/2017 6:29 am
Run one for ages now and it's great, the bag is made really well and comfy when riding. The bladder is great as well, no issues with leaks or anything and it works......for £29 it's a bargain.
Posted : 21/06/2017 7:38 am
I bought 2 and they both failed where the tube meets the bladder. I like the fact the whole end opened for filling but I think they are just too weak. Pitty really.
I should have sent them back but they just got binned in the end.
Posted : 21/06/2017 9:09 am
I've had one for 9 years, it only just went mouldy this year.
I would buy again.
Posted : 21/06/2017 9:11 am
they are just cheaper in every way.
Joints / bite valve / hose less flexible / simplistic opening.
I use the Decathlon rucksack which is equal or better than my Camelback equivalent but always use the Camelback bladders
Posted : 21/06/2017 9:12 am
The bladder is fine, full opening top is great.
Similar experiences on the valve though. Mine split after about 6 months so need to lock it every time to stop it dripping on my leg. However, the push/pull locking bit is very stiff and difficult to do one handed while riding.
I've now gone back to a bottle in a cage as I get paranoid about running out when using a bladder and not being able to see how much is left so I tended to under-hydrate.
I'm still using the associated backpack from Decathlon though to carry stuff and a spare bottle for longer rides.
Posted : 21/06/2017 9:47 am
Just picked up a £9 Mountain Warehouse hydration bladder, I needed it for tonight.
It's pretty good, I've filled and it squeezed it and it doesn't leak, or rather doesn't now i've tightened everything.
I think i'll stick to plain water though, it doesn't proclaim to have any anti-bac qualities.
Posted : 21/06/2017 11:54 am
