Not sure if this has been done already -
http://www.decathlon.co.uk/chain-whip-cassette-remover-id_8309913.html
Anyone tried one? Looks spot on and an improvement over a traditional chain whip.
I bought one for use at work. It's brilliant. I've had bikes in where the cassette is so worn the chain whip skips and some where the lock ring is so seized the chain has broken. This tool has never failed though.
I like that!
So simple, but so effective. May have to pop down and buy one.
Think I'll go grab one tonight then, snapped by cheap chain whip yesterday.
I too am on the hunt after snapping the chain on my chain whip.. What exactly does it lock onto though.. Do the round nubs sit between the sprocket teeth?
yes - there's a video on the decathlon page showing in it action.
I'm sure someone will be along in a minute to call me an idiot - but how come this has never been done before, just seems so simple.
And if you are running a 12-25? Are there different patterns for dofferent sprocket So?
EDiT. Double sided :-). Nice. Wonder if it can handle my track sprockets?
yep, on the other side to the one shown in the pic. same pattern, different spacing.
Thanks.. I was going to ask about 12t.. Does it cope with the new 10t sprockets too? Not that I have or intend to get a 10t..I'm sold I'm gonna buy one.. Little bit more than I want to spend but it looks like an improvement on traditional chain whips.
I've been using the pedros vice whip (or similar name...)
Spendy but never regretted buying it.
Doesn't do 10t..but hey.. I'm very tempted anyway.. I've always found chain whips to be a complete pain in the proverbial.
Its a copy of [url= http://www.jastein.com/Html/Hyper-Handle.htm ]this.[/url]
Edit - they've been around for a loooonnnggg time. I guess that no one knew about them since they aren't blue...
Another Pedros Vice Whip here, loads less faffy than a normal chain whip. Looks like the price has gone up a bit though - mine was only about £35! Which I admit is still quite a lot...
Decathlon idea looks good for 12 quid though!
'hyper handle' obviously need to step up thier game in the marketing department then!
The principal seems much more sensible than wrestling with a chain whip.
The only concern with these is the handle looks quite short, but if they grip better then great.
Went and picked one up last night, just took my cassette off in minutes, the same one that snapped my chain whip.
Are you all trying to use the chain whip with it wedged between your buttcheeks ? Ive never been able to describe my useage of a chain whip as wrestling,
Those pedros vice cassette grips are good unless it been put on by a hamfisted oaf when it was built and ergo tight
Or your trying to remove a very tight track sprocket. I struggled with leverage with the vice grip one.
Park sr2 provides plenty leverage to get most stuck things off 🙂
I bought one of the Decathlon tools yesterday, Ive killed two chain whips trying to get a cassette off a wheel, this was a revelation and worth every penny compared to the the standard style.
I have a unior one. It's brilliant.
I also have a Pedro's vice whip but never failed with the chain type. If the cassette is that badly worn, wrap it around a smaller sprocket so the whip presses down on the free end of the chain.
