Debonair high psi i...
[Closed] Debonair high psi is this normal ?
[#9932571]
Hi
I've recently purchased a fairly new RT3 debonair for my Meta I'm 16 stone without kit on now running the debonair at 300psi it still has 30mm sag is this normal or is it playing up ?
Any advice warmly welcome
Mark
Posted : 08/04/2018 8:34 pm
I've had a couple of those and think I'm normally about 250psi, with 30% sag. And I weigh about 12st.
So it doesn't sound too unexpected.
I'm sure others will have more useful advice, but if not maybe give TF Tuned a bell.
Posted : 08/04/2018 8:44 pm
I have 320 psi in mine so not unusual.
Posted : 08/04/2018 8:45 pm
Cheers you two puts my mind at rest
Posted : 08/04/2018 8:59 pm
In general heavier riders can benefit from the smaller aircan. Otherwise you might blow through the travel. That's the experience I had. A HV air can made a massive difference from the debonair I had before.
Posted : 08/04/2018 9:35 pm
Isn't the max recommended psi 275? Seems they can obvs handle more!
Posted : 08/04/2018 9:47 pm
350 max psi on the new boxed RS Monarch Debonair Plus RT3 I've got
Carlos
Posted : 08/04/2018 10:12 pm
Mine too Carlos says 350psi on the shock itself
Posted : 08/04/2018 11:02 pm
275 on the HV air can.
Posted : 08/04/2018 11:03 pm
300+ on mine too, & ive added a band into the negative chamber to stop it blowing through the travel (suggested by a suspension tuner)
Posted : 09/04/2018 2:02 pm
13st - 210psi on mine. 4 bands in +ve and none in -ve.
Posted : 09/04/2018 2:57 pm
