Dead Garmin
[Closed] Dead Garmin
[#5699591]
1 hour in the rain, pretty sure it was mostly covered for that time, I plugged it in to hear a beep then the screen go blank...I've taken the back off and left it on a book on the radiator, no change yet.
It's a 2 month old 210, should I be surprised? I can get it warrantied as I work for a retailer, but am not impressed...
Posted : 17/11/2013 6:55 pm
A little silicone lube (not sealer), on the small rubber closure for the charger makes it slide properly closed...
I found when it was dry mine couldnt be trusted to seal properly...
Posted : 17/11/2013 6:58 pm
 dobo
forerunner 210? its not broken! probably.
it just needs a hard reset. dont take it apart!
do a google, theres a certain combination of button presses that resets the watch and it will spring to life.
ive had it happen a couple of times and never remember the button preses and usually just press them all a load of time and sometimes it comes back.
mines been plenty wet and works fine just try not to submerge
Posted : 17/11/2013 7:41 pm
The famous leave it in a bowl (or bag) of rice trick? (along with the reset advice above)
Posted : 17/11/2013 7:48 pm
My garmin 800 has been in some wet rides lately - and has now stopped calculating elevation. Every ride appears to have been almost flat on the elevation graph when downloaded 😕
Unfortunatly, mine is out of warranty 🙁
Posted : 17/11/2013 7:52 pm
I just had mine fall off the road bike. Do garmin offer a crash replacement service?
Posted : 17/11/2013 7:54 pm
I don't know what happens within warranty but I got a vastly reduced unit when I destroyed the screen of mine when I went otb.
Posted : 17/11/2013 8:05 pm
Have no problems with Garmin warranty. Have had a new HRM from them as I thought mine was broken (turns out my heart rate is just extraordinarily high!). Then the cadence/speed sensor broke. They send a new one, no questions asked, and it came next day.
Posted : 17/11/2013 8:27 pm
It won't even switch on, so a reset appears impossible.
Posted : 17/11/2013 10:51 pm
My 510 died last week, on/off button stopped doing anything but when I touched the screen the start screen would flash up and then go off a second later. Tried all the reset procedures with no joy. I noticed the week leading up to the total failure that when switching it on the screen would flash 7 - 8 times as if resetting itself, the battery would then show 100% when it def wasn't. Pretty frustrated actually, it's only 3 months old, failure started after a particularly wet/cold ride. Sent it back a week ago but according to the bike shop Garmin haven't even looked at it yet, they're "working" on a two week turnaround.
Posted : 17/11/2013 10:57 pm
Though garmin are really good for waranty and out of waranty isn't it a simple case of returning to store for replacement?
Posted : 17/11/2013 11:06 pm
I'd hoped that would be the case (instant replacement) but shop said they'd have to send it back.
Posted : 17/11/2013 11:09 pm
 dobo
yep thats what usually happens with mine, no screen or functions whatsover, try the various reset methods, if i recall the hard reset wipes previous data on watch
http://it2tp.wordpress.com/2011/12/28/resetting-a-garmin-forerunner-210/
Posted : 17/11/2013 11:46 pm
Cheers dobo, I'll give that a try.
Posted : 18/11/2013 5:52 pm
Worked a treat, cheers!
Posted : 19/11/2013 12:39 pm
The charger for the Forerunner 210 is piece of shit design. Getting the clamp to line up and the pins to engage is far more faff than it should be and I think is the cause of lots of random shutting down and inability to turn on properly.
The plastic cradle for the Forerunner 10 is much better.
Posted : 19/11/2013 1:20 pm
Agreed.
Posted : 19/11/2013 1:32 pm
