darkside meets MTB ...
[Closed] darkside meets MTB question
[#609430]
Will a newish style Shimano 7800 (not the brand spanking 7900) duraace crankset with external BB fit a Santa Cruz Blur. Is the bb shell of a MTB to narrow to fit a road crank?
Think it would look good but dont want to buy one and try and fit it as the shop wont take it back, anyone tryed it?
Cheers J
Posted : 05/06/2009 9:17 pm
If the Blur has a 68mm BB shell it should fit fine. Don't think it will fit a 73mm shell.
But would you want 53/39 chainrings on your MTB? And would the front mech fit around the suspension linkages on the blur if it was above a 53 chainring?
Posted : 05/06/2009 9:20 pm
and might the rings foul the stays (or are you putting smaller ones on)
(whatever happened to the guy with the anthem and the crushed BB ??)
Posted : 05/06/2009 9:26 pm
compact 50/34 should work i think
Posted : 05/06/2009 9:54 pm
 mrmo
probably find the crank arms foul on the stays regardless of ring size.
Posted : 05/06/2009 9:59 pm
Cheers chaps, will do some measuring, never even thought of the size of the rings !!!!!!
Posted : 05/06/2009 11:05 pm
Then you're a moron! 😉
You can't fit smaller than a 34t inner on there, so you'll need some fairly big legs. Unless you buy a triple, when you can have a 30t inner.
Posted : 06/06/2009 9:17 am
