Hi,
If you see the rs catalog the spec of the dampers 2017 of this forks are the same, it changes only lockout ,wire Vs hidraulic. But do you know if the damper is the same? Or the xx has something more? Because I like improve my RL keeping the handlebar lockout. The lockout of xxaybe has some regulation more? Low speed or other else?
I like to have a similar dumper to rct3(low and fast speed) but the possibility to lock out by handlebar, without spend so much money buying a charger dumper kit. Thank you
Posted : 14/09/2017 2:48 pm
