Damage - I assume t...
[Closed] Damage - I assume this is terminal
[#5475247]
I crashed heavily in May - the damage to me I [i]thought[/i] was worse than to the bike (my shoulder is ****ed and I'm having surgery on Friday). I had been riding my Scandal since without evident problem but I bought a nice new Soul in July - for reasons of 'I need one' rather than any suspected problem with the Scandal.
However, I was cleaning the frame with a view to selling it (I won't now) and noticed this - given the characteristics of thin-walled Aluminium tubing I assume this dent constitutes an important structural weakness in the bike and it would be unwise to attempt to ride it.
What does the panel think?
Posted : 01/09/2013 10:04 am
I would ride it. Buying would need a hefty reduction in price but if it were already mine......
Posted : 01/09/2013 10:06 am
Personally, I'd keep riding that. I'm sure there are loads with similar dents that have ridden without problem.
It'll be worth asking Brant, or On-One, as they'll know the properties of their tubing best.
Posted : 01/09/2013 10:07 am
Assuming the crazing/crackling is just the paint it looks all right for you to ride.
Posted : 01/09/2013 10:12 am
Ride it until it breaks. If it does. I had a bigger dent than that in the tt of my bullit and it survived a lot of abuse and believe its still being ridden hard by its current owner.
Posted : 01/09/2013 10:25 am
My old Orange had two things like that on the downtube - rode it for 6 years like that...
Posted : 01/09/2013 10:32 am
 grum
I've got much bigger dings/dents in my frame and been riding it for years. Admittedly they are in the bottom bracket area which I would guess has thicker walls.
Posted : 01/09/2013 10:34 am
I'd ride it - it's not crumpled, and it doesn't look that deep.
Posted : 01/09/2013 10:35 am
OK. Thanks
Posted : 01/09/2013 11:48 am
Nice frame
Posted : 01/09/2013 11:52 am
Posted : 01/09/2013 11:56 am
Looks OK to ride but might depend where on the bike it is and whether it could cause the tube to buckle under heavy loading. Looks like the downtube? If so you'd get some warning as the downtube is mostly in tension, with a bit of sideways bending. Top tube I'd be more worried.
Posted : 01/09/2013 12:08 pm
My Scandal has the same kind of thing on the down tube from a rock strike, I've happily ridden it for a year since without having died.
Posted : 01/09/2013 12:16 pm
I've often wondered if the people that repair dents on cars would be able to fix something like this
What they do on cars is amazing
Posted : 01/09/2013 12:18 pm
As it's on the downtube I'd keep riding it, under tension there as has been said.
Posted : 01/09/2013 12:25 pm
Is the frame a 26". if so i might have it off you for the right price.
Posted : 01/09/2013 12:28 pm
That's just filler - cosmetic, not structural.
Posted : 01/09/2013 1:03 pm
Got much worse dents in my Scandal and still ride it . Been there for over a year and all is fine.
Posted : 01/09/2013 3:53 pm
You could tack a wire into it car repair style but a slide hammer to pull it out before filling would be a bit excessive :O)
Posted : 01/09/2013 4:06 pm
It'll be fine - adds character.
It looks close to something that may fail over time. My stump jumper took 5 years to finally start cracking from a dent which had corroded. My dent did look a little bit worse. I would ride it as long as it is in a visible place that you will subconsciously check from time to time. . :mrgreen:
Posted : 01/09/2013 4:11 pm
I had similar in an aluminium frame a few years back, i marked the frame at the points where the ding ended, i.e. marking where the ding ended, and then monitored this to make sure it didn't grow. In the end the frame died from another crash.
Posted : 01/09/2013 4:25 pm
I dinted my Inbred (steel, obvs.) on the first ride, and significantly worse than that. I fell off onto the only boulder in the field. It must have been magnetic...
Posted : 01/09/2013 4:55 pm
