Daily Commute helme...
[Closed] Daily Commute helmet (moon on stick)
[#10482942]
Want:
* Daily usage cycling helmet
* Good airflow
* Prefer MTB to roadie styling.
* The less padding to soak up sweat and go manky the better
* Durable padding - should survive weekly (or more) washes in washing machine
* 59cm head, regular shape???
Past helmets:
* Catlike Leaf, favourite of recent times, a good fit, even after pads were thrown away.
* 661 Recon Scout helmet another good fit but padding is deteriorated < 1.5yr
Any recommendations?
Posted : 11/02/2019 10:26 pm
 ton
just what you described
https://www.wiggle.co.uk/giro-foray-helmet/
Posted : 11/02/2019 10:37 pm
More gentle washing of pads, buy spares etc.
Posted : 11/02/2019 11:09 pm
You wash your helmet pads weekly?! Wow, mine get a light hand wash when the smell gets bad, once a year tops I think.
Bar that, my answer would be a cheap On-One/Carnac job. You can pick up a perfect good lid for £15 easily enough.
Posted : 11/02/2019 11:14 pm
Cycling twice a day, minimum 5 days a week, often six, mostly short rides, but enough to get hot and sweaty.
Guess I could get a haircut! Shaved would be the functional ideal, but not my best look, and not allowed.
Posted : 11/02/2019 11:33 pm
 geex
No helmet ticks all your *wants nicely
Posted : 11/02/2019 11:38 pm
The trouble with the On-one XC offering, and others which go from 58-62, is they tend to wobble side-to-side on my 59cm head.
There's this MET road/mtb helmet:
https://www.merlincycles.com/met-crossover-road-mtb-helmet-94869.html
Posted : 11/02/2019 11:44 pm
Ahh, think I know where you're going Geex.... no helmet right? That's what you said.
Posted : 11/02/2019 11:46 pm
Speaking as a no choice badly I wouldn’t. No hair to help soak up sweat makes it worse and also leads to sweat eye.
Posted : 11/02/2019 11:58 pm
The washing machine isn't magic, just rinse your pads under the tap, perhaps a tiny bit of soap and then squeeze the water out or pat between a towel 🙂
Posted : 12/02/2019 6:45 am
https://www.decathlon.co.uk/500-mountain-biking-helmet-black-id_8328686.html
I’ve got one of these from Decathlon - used it for mtb several times a year for a few years and it was comfy. Now use it for night mtb-ing with a light on top of it.
Maybe I’m minging but I’ve never washed the pads in it.....
My newest mtb helmet is a Giro Chronicle and that is a slightly more snug fit - but it runs a lot hotter.
Posted : 12/02/2019 7:16 am
Louis Garneau Edge is what I use daily (fits your description). Comes with spare pads, which i haven't had to use yet, almost 2 years after purchase.
I find (tip!) dabbing the pads with kitchen roll immediately after a ride stops pads going stale and avoids needing to wash them weekly (or even monthly).
It's the big central vent which makes for a cool helmet (arf) ime.
Evens don't seem to have the Garneau anymore so you'd have to hunt around.
Posted : 12/02/2019 11:55 am
if you sweat that much then a buff would be a prudent easily washable non fallapartable thing that could be worn under your helmet.
I wear one all year round - prevents sweat eye as well.
as for the helmet.
which ever specialized helmet fits your budget. Ive found them to be the best alrounder for style/budget/venting/comfort
Posted : 12/02/2019 12:02 pm
I wear a buff under my lid which extends the pad life enormously. If you need max ventilation to counteract a very hot head then may limit the effectiveness of that, but it works for me.
edit - beaten while typing.
Posted : 12/02/2019 12:03 pm
My helmet goes in the shower with me after cycling. the pads get washed and rinsed when I do.
Posted : 12/02/2019 12:54 pm
Have a look for a Catlike Vacuum
Excellent airflow, comfy, pretty cheap, stylign fits what you're after - has a little detachable peak
Posted : 12/02/2019 3:07 pm
 jca
May I point on that a moon on a stick will probably exacerbate the effects of any cranial impacts rather than reduce them...YMMV...
Posted : 12/02/2019 6:19 pm
Cut a Buff type thing into smaller strips and wear them over your forehead as a sweat band then add helmet
Posted : 12/02/2019 8:34 pm
Or just use a headband 🤔
Posted : 12/02/2019 8:39 pm
Just in case anyone is interested, I got an Alpina MYTHOS L.E. MTB Helmet, and a spare pad set too, for £45, from bikediscount. Also discovered the straps are easily removable so they can be washed as well. It's also well ventilated and reasonably comfortable (especially now that I've bothered to adjust the straps properly).
Posted : 10/04/2019 9:25 pm
Another cute for the decathlon one
I bought it as a stop over until I replaced my giro
Turns out the decathlon one is great, 12+months now not washed the pads yet🤢, tough, vented, comfy.
Safey first hi Viz too
Posted : 10/04/2019 9:49 pm
You can get a Giro Hex in large for the price of the Foray atm. If you liked the Catlike you'll love this
All the Giros
If you're on a tight budget, the Giro skyline on the next page is in your size and is only £22.
Good thing with the Giros is its easy to buy replacement pads too.
Posted : 11/04/2019 7:32 pm
