CX wheels help
[Closed] CX wheels help
[#10313447]
Hi guys I’m in need of a little help.
Ive bought a CX frame, partly for a bit of fun around the woods and partly for a commute as I wanted disc brakes.
My original plan was 2 wheelsets one for each condition.
But I’ve gone and bought a Cx frame with a 15mm thru front and 12mm rear. All the cheaper road disc wheels I had seen were either 12/12 or QR.
My budget was around 100 per set, but most of the 15/12 wheels for cx seem to be over £200!
Then I found the old canyon CX actually used crossrides, these are pretty cheap and would make a good enough wheel for now, but I’m getting a bit confused with all the standards.
The criticism of using 29er wheels on a cx seems to be with the tyre width? Not being able to run 33-38 tyres easily. The old crossrides seem to have an 19mm internal width, the newer ones say 21, but on the Mavic site it says they will take 36mm tyres
https://shop.mavic.com/en-gb/crossride-fts-x-rv0836.html#1028=3283
Any thoughts?
can this work ok for now?
The dropouts on the cx frame are 142, so match the crossrides.
Posted : 06/11/2018 10:59 am
crossrides or similar will be fine, Halfords used to spec their cross bikes with mavic xm319 rims which are mtb but narrower than is popular now (I actually sold a new pair on ebay recently for wee money)
Posted : 06/11/2018 11:18 am
21mm internal width rims are fine for narrower tyres.  I was running 25c on a 21mm internal with no issues whatsoever
Posted : 06/11/2018 11:25 am
I run 38c on a 25mm internal rim no problem.
Posted : 06/11/2018 11:31 am
So this should work?
https://www.chainreactioncycles.com/mavic-crossride-rear-mtb-wheel-12x142mm-cl-/rp-prod173307
I presume CL is centerlock? Does this pose any issues or is it just rotor choice.
Posted : 06/11/2018 11:53 am
Just rotors, but you can get a centrelock to 6-bolt adaptor if you wanted to stick with regular rotors/have a stash to use.
Posted : 06/11/2018 12:24 pm
Don't worry about internal width, I've got 32mm road tyres on a set of 21mm internal DT rims
Posted : 06/11/2018 1:08 pm
Hope Hoops with the 'XC' rim work great for a CX bike, and the narrow CX rim is the least popular/trendy variant so they tend to be good value.
Posted : 06/11/2018 1:30 pm
