CX racing wheels an...
[Closed] CX racing wheels and tyres - what do I need to know?
Ferrals, tubs sound essential to me 😉
Re tubs, what's the thinking with rim width? I've got some old 50mm ones in the shed that I could cannibalise but they were road ones and are probably quite narrow. Spoke count might be quite low too.
Posted : 27/07/2017 9:23 pm
 LS
They'll be fine. I ran 16 spoke 45mm fronts for years without any issues at all (the braking surface wore completely through and they still didn't need touching with a spoke key), and they were standard road rims of the time so not the new wide ones. It's the shape rather than the width that matters, they need to be nice and shallow.
Most carbons are, it's the older alloy v-rims which cause issues as the base tape can't follow the profile of the rim properly and so doesn't stick on well without bodging.
Posted : 27/07/2017 9:52 pm
Thanks LS, I'll go dig them out tomorrow. They're the Planet X 50/50 tubs. May be a cheaper option just to get some hubs and build them up.
Posted : 27/07/2017 10:04 pm
 LS
Nick Craig won an Elite national title on those wheels so I'm sure that they're good enough 😀
Posted : 27/07/2017 10:06 pm
Hmm front is 20H, can't seem to get disc hubs for them, probably for good reason. Oh well.
Posted : 27/07/2017 10:31 pm
Say I have an aversion to PX, and the Kinesis wheels seem too heavy.. what other options do I have for a tub wheelset (discs 12mm through axles) that are reasonably priced?
Posted : 28/07/2017 10:21 am
Strada seem a pretty good bet [url= http://www.stradawheels.co.uk/product/34mm-tubular-carbon-wheelset/ ]here[/url]. Depends on what you mean by reasonably priced I guess. Other than that I think it's likely Chinese direct carbon or ebay.
Posted : 28/07/2017 11:31 am
They look bang on, thanks. It's not going to be an imminent purhcase but good to have someithng in mind.
Posted : 28/07/2017 11:55 am
I went with these clinchers https://www.bike-discount.de/en/buy/dt-swiss-r-23-spline-disc-ta-11s-shimano-wheelset-502783/wg_id-12981 for £330 - the come complete with all the adapters, lock rings, tubeless ready, valves etc. Mine are for the odd race and local trail rides.
1655g
Posted : 28/07/2017 12:24 pm
Guy on Central league FB selling various unused tubs for about half price
https://m.facebook.com/CentralCXLeague/posts/1481022138646379
Posted : 29/07/2017 5:09 pm
Thanks for the link. What's the thinking on baby limus? Would you have it as your mud tyre or is it more intermediate?
Posted : 29/07/2017 6:22 pm
Baby limus is a great all rounder and really works well in all conditions.
As to the tub argument I have to agree that they are significantly better, however I wouldn't recommend anyone in their first season using them.
Thing is, you'll be racing most weekends, and in between you'll be training. cleaning kit and mending stuff. There simply isn't enough time to be stripping off a punctured tub and gluing up another. It adds another layer of stress on to an already exhausting schedule.
I'd recommend buying a set of Baby Limus open tubulars, use inner tubes and lean not to pinch flat them (ride light) so you can run 20psi both ends.
Tubs will make a difference of a place or two in some races. Fine if you want to get from second to first place but not worth the hassle whilst you learn the craft of getting bike and body to the finish line in one piece a little further down the field.
Posted : 29/07/2017 6:39 pm
Baby Limus, excellent tyre. Wide spaced and smaller nobz, grip nicely and corner well. I didn't go as low as 20psi, normally stay around 28-30psi for all round conditions.
Posted : 29/07/2017 6:43 pm
rollindoughnut - Member
Totally agree; you more likely to finish higher by just getting fitter ... I know thats not the easy quick fix answer some will want, but unfortunately its the blunt truth.
I run clinchers - usually position in the top 10 of my category ... and apart from 1 or 2 courses, I have never felt it is grip that is holding me back from a position or so higher; its always my legs/lungs that are the weakest link.
Posted : 29/07/2017 6:55 pm
Thanks chaps. May well do that while dipping my toe in for first season then look to tubs next season if I get on ok.
So open clinchers and latex tubes or tubeless? Expect the former to be better at lower pressures if you can avoid the pinch flats.
Posted : 30/07/2017 2:57 pm
Uh, in that case- get the Tubs MrBlobby 😆 😀
Posted : 30/07/2017 3:30 pm
I use butyl tubes on clinchers (cheaper and maybe tougher?). I've not found tread patterns I like as much as the Challenge open tubular range in other manufacturers tubeless designs plus the tubeless I did try either suffered from unsealable sidewall nicks or burped air. The only ones that worked were the Bontrager range but these tread patterns are far behind Challenge tyres.
So to surmise, If you are buying two tread patterns then make one a limus and the other a griffo, if just one (which I recommend; less to worry about) then I think the baby limus is the best all rounder. I use this tyre from road/dust/gravel trough to thick mud as it stays on my training bike all year. Current set, rubber lasted 9 months although it's very worn now and I got 3 punctures in total (2 pinch flats and a thorn).
I vary the pressures between 20-35psi depending on what I expect to come across on my ride.
On a 'cross race course, you can identify any feature that can cause a pinch flat during your pre-ride laps. There will often only be one or two hazards a lap and you can choose whether to hop, ride around, slow down or dismount for them. Therefore on race day you can drop to silly low pressures and really enjoy the feeling of floating around on a set of cushions. Beware though, when you stand up and sprint or corner hard you may cause the tyres to fold over which is a whole new thing to learn to deal with. It's such a cool game!
Posted : 30/07/2017 5:16 pm
Thanks rollindoughut, loads of good stuff there.
Got some MXP on the way. Shall try them tubes and tubeless and see how it goes.
Posted : 30/07/2017 6:03 pm
Did you get the tubeless version of the mxp or the normal? Tubeless much less supple but very easy to run tubeless, I wouldn't bother with tubes if you have the dedicated tubeless ones.
Posted : 30/07/2017 6:54 pm
Had ordered them thinking I'd run the MXP tubeless. Then get something softer to run with latex tubes for when it's muddy.
In light of above I'm wondering if I should have gone for a griffo with a latex tube instead.
Probably overthinking this seeing as I've not even raced yet 😉
Posted : 30/07/2017 7:34 pm
Nobody on here has ever done that before 😉
Posted : 30/07/2017 7:40 pm
Bikebuoy is that the SDW where it meets the railway line just north of Meonstoke?
Posted : 30/07/2017 9:20 pm
I really like Baby Limus. Very versatile.
Ideal set up for me, with the little finesse and skill I have, is Limus front and Baby Limus rear. I have Cole 38mm section wheels and some Ambrosio alloy rims on Hope hubs. I prefer the Ambrosios. Stiff and light. Not run tubeless but latex tubes in open tubs which worked well for training and spares.
If you don't want spangly Carbon you can probably find alloy wheels for Tubs for a good price.
I used the Chinese Carbon wheels with Novatec hubs for a couple of years with no issues.
Posted : 30/07/2017 10:14 pm
I agree - Munqe Chick won the Central womens league overall '15-'16 season, and came second '16-'17 season on clinchers 8) I bought the tubs last year half way through my second season; I had my highest placing riding them but I also got physically stronger as the season went on so couldn't attribute that to them, but they are a genuine performance improvement. I wouldn't buy tubs until I knew I actually enjoyed racing, but as Munqe Chick and I are mad for it (doing as many races as my shift work allows) they were a worthwhile outlay.
well, we ended up buying the unused Baby Limus off the link on the basis Munqe Chick will be going tubs next year 😉
Posted : 01/08/2017 9:29 am
Well one of the MXP arrived this morning. I shall get some of those Novatec wheelsets, pop them on, and go racing 🙂
Posted : 01/08/2017 10:00 am
Quick one for you lot. If I do go for a clincher mud tyre do I go tubeless (like a PDX maybe) or open tub (like a Limus) with a latex tube? Thinking the latter might work better at lower pressures.
Posted : 01/08/2017 2:53 pm
Unsure of tubeless option but i've run some pretty low pressures with a latex tube and PDX clinchers. Weirdly the pdx clinchers came up wider than the tubular version for me.
Posted : 01/08/2017 3:35 pm
I read that was because the clinchers are 'generous' whereas Clement were aware those using tubs might get their tyres measured and so made sure they were bang on the UCI reg. 33
Posted : 01/08/2017 3:38 pm
I was the one who bought the used Limus and Baby Limus... sorry!
Posted : 01/08/2017 4:14 pm
 Jase
Anyone know where cx latex tubes can be purchased?
Posted : 01/08/2017 4:50 pm
chain reaction had stock briefly this weekend. you need to set up stock noification and be quick!
Posted : 01/08/2017 5:01 pm
My LBS has loads of the challenge ones 🙂
Posted : 01/08/2017 5:04 pm
 Jase
Done
Posted : 01/08/2017 5:08 pm
Munqe-Chick raced the UK nationals in 2015/16 with PDX clinchers, they technically failed the UCI caliper test on the start line but as she posed little threat to Wyman, Harris etc they let her race 😉
Posted : 02/08/2017 8:53 am
Latex tubes..
Really [i]that[/i] good, or just a waste of caaaash.? I tried them once, thought them an extravagance.
Posted : 02/08/2017 9:31 am
Tubeless clements mxp for most conditions in the sw.
Posted : 02/08/2017 9:49 am
crashtestmonkey - Member
Do they check everyones tyres at a national? how far out were the PDX's? wonder if it was an unlucky tyre/rim combo?
I will be entering the Aberavenny one, running 33c labelled mxp or pdx clinchers depending on conditions (I've given up on the idea of tubs for this year, I jsut don't ahve the money). I'm likely to be pulled out before the end anyway, but would be a shame to turn up and be told to go home!
Posted : 02/08/2017 9:55 am
 LS
Yes they do, but only for the UCI categories. Both tyres are checked with the plastic templates that the comms carry and random checks are done on the pit bikes too.
I've pulled a rider from the start line of a World Cup race, so it does happen! (They did have a mech on hand who swapped the wheel to a legal one, but it meant they started at the back of the grid...)
Posted : 02/08/2017 10:03 am
Cheers, I'll have to double check tyres widths on my rims then. So there's not much point entering if tyres do come up over 33mm?
Shame as I really fancied racing on a more cx-technical course, typically I find the regional races are nowhere near as technical as the drills I do in practice.
Made up some hurdles last night at a UCI regualtion 40cm too for practise 😳
Should start up a 2017-18 cx racing thread soon with all this chat going on 😀
Posted : 02/08/2017 10:41 am
Ferrals, do it, get a CX thread going. Apparently cross is coming!
Spent quite while going round in circles at a local park jumping off and on the bike last night. Managed mostly to avoid any gusset issues 🙂 Need to get some hurdles knocked up next.
Really that good, or just a waste of caaaash.?
Definitely worth it for road. For CX I've only done a couple of rides with them but I think the stock tyres aren't really supple enough to feel the difference. And I pinch flatted, second ride at 15 quid a pop 🙁 Now set up tubeless on that wheelset.
Posted : 02/08/2017 11:17 am
apologies if not clear, this was [i]The[/i] National Champs, not a round of the nationals, so full UCI commy.
Posted : 02/08/2017 11:54 am
@mrblobby, get a set of cones off amazon too, can get 60 of the school sports type for about £15
prepare to get funny looks off people though!
@ctm, ah cool.
Posted : 02/08/2017 11:55 am
 LS
apologies if not clear, this was The National Champs, not a round of the nationals, so full UCI commy
I think that you were lucky to get someone in a very good mood!
UCI Trophy rounds have full UCI comms on duty with a foreign UCI comm as president, so if anything should be stricter than the national champs (where it's all UK-based UCI comms leading)
Posted : 02/08/2017 12:26 pm
It's [url= http://singletrackworld.com/forum/topic/20172018-cx-racing-thread ]Here[/url]
Posted : 02/08/2017 12:32 pm
Page 2 / 3
