CX chain rings..
[Closed] CX chain rings..
[#3811399]
Given that I mostly use my CX bike as a road bike, I'd like to increase the size of the chain rings. Currently running a 36/46 double. Can I just stick a 53 outer ring on and adjust the mech/ chain as appropriate or will the jump from 36 be too much?
If both rings need replacing then a new chainset probably works out cheaper!
Also, are mini V's any better than cantilevers, or should I just stick with what I've got (Avid shorty's)
Thanks
Posted : 26/03/2012 9:16 pm
How often are you spinning out the 46-11, or the 46-12?
Posted : 26/03/2012 9:18 pm
Not spinning out per se, but could push a bigger gear for more speed.
Posted : 26/03/2012 9:32 pm
