CX bike setup
[Closed] CX bike setup
[#2923882]
I recently got myself a TCX2 CX bike but can't seem to get comfy on it. I'm not sure what's wrong, I've used my road bike as a template and all the major measurements are the same (saddle height, for-aft position, saddle to hoods etc). I'm I missing something? Should a CX bike be setup differently to a road bike? It's strange that I can't decide what's wrong, i only know that it doesn't feel right.
Posted : 07/07/2011 7:45 pm
 LS
First measurement to set is saddle nose behind BB at correct height (assuming saddle is the same as on the road bike) then set everything else accordingly.
Probably quite a few differences in geometry between the two (seat angle, tt length etc) that you need to account for. Also pedal stack height differences.
Posted : 07/07/2011 7:54 pm
Saddle is the same as the road bike, setting the same saddle nose-BB setback results in my knee being too far back. I can't get my head around this, different geometry or not. Maybe it's because my road bike is a Cervelo S1 which has an offset BB, still don't really understand though! Saddle height and shoe stack are ok.
Posted : 07/07/2011 8:37 pm
Please don't take this as sarcy but its not a road bike so why set it up as one? It's probably a good starting point for you if your road bike fit is dialled but don't be scared to try other set ups. Personally i'd probably try the h'bars a bit higher and tweak as you go along. But then I'm a CX riding MTBer not a roadie.
Posted : 07/07/2011 9:35 pm
Fair enough. The bars are a very different height, Im not trying to match everything, just the basic height reach measurements. Trial and error I guess is the answer.
Posted : 07/07/2011 9:43 pm
had same problem had to flip the stem so the it was a 6 degree rise instead of a fall and since then its been really comfortable.
Posted : 07/07/2011 9:44 pm
Seat height bar reach I should say.
Posted : 07/07/2011 9:59 pm
 olie
or you could go see a bike fitter.........................
Posted : 07/07/2011 10:01 pm
Check your hoods position too and the reach and drop of the bars.
Posted : 08/07/2011 8:05 am
