Cutting down carbon...
[Closed] Cutting down carbon bars
 gj78
[#3363776]
Whats the best way to cut down some carbon bars?
Posted : 18/11/2011 10:17 am
half from each end, not all off from one end.
HTH
 gj78
Thanks Einstein! 🙂
Posted : 18/11/2011 10:20 am
I'd take out a bit from the middle so the grips & levers can still fit properly
Posted : 18/11/2011 10:22 am
A hacksaw with a blade made for cutting carbon or get you LBS to do it for you.
Posted : 18/11/2011 10:23 am
Fine-bladed hacksaw or Dremel. Watch out for the dust, if you're paranoid that way.
Posted : 18/11/2011 10:29 am
Use a new blade with 32tpi. This is all your LBS will do.
Posted : 18/11/2011 10:30 am
As phil says, just do 10mm at a time and try out though.
Posted : 18/11/2011 10:36 am
