Cutting and editing...
[Closed] Cutting and editing Garmin GPX files.
[#4162547]
I left my Garmin running in the car and have messed up the averages for the days riding, is there any way of chopping the last hour off the ride.?
Posted : 14/07/2012 10:36 pm
you certainly can on Strava. Not sure if you can on Garmin connect though.
Posted : 14/07/2012 10:39 pm
How if you don't mind me asking.
Posted : 14/07/2012 10:41 pm
Open the GPX file in notepad or other text editor and remove the last hours records.
Just leave the closing bit of the XML and change the time to the same as the last point.
Posted : 14/07/2012 10:42 pm
neilsonwheels - Member
upload to strava then go to the ride in question. select crop ride from the actions drop down.
Further info here if my description wasn't clear [url= https://strava.zendesk.com/entries/20965873-crop-tool-for-activities ]Link[/url]
Posted : 14/07/2012 10:43 pm
geoffj - Member
+1
Posted : 14/07/2012 10:46 pm
Cheers all.
Posted : 15/07/2012 9:42 am
A lot easier using this.
http://sourceforge.net/projects/gpxeditor/files/
Posted : 15/07/2012 9:46 am
You can also use Mapsource.
[url= http://www8.garmin.com/support/download_details.jsp?id=209 ]Download[/url]
If you unzip the package with winzip or similar then run the exe file directly it installs fine.
Posted : 15/07/2012 9:56 am
Drac - Moderator
unless you use a Mac and/or have half an idea of how XML files work.
Posted : 15/07/2012 1:41 pm
GPSBabel is another free tool worth downloading. Converts GPS files from/to pretty much any available format and has a neat filtering function so you can say 'chop off everything after 15:35' for example.
Posted : 15/07/2012 7:32 pm
Garmin's Basecamp is pretty good for this - once you work out how to use it. It's not the most intuitive software going, but you can chop off bits of the ride from the map view by using the "Divide" button.
Also comes in handy when you accidently turned the dam thing off during a ride. Load the track into Basecamp, edit it in the Map View using Insert waypoints. Then export it as a track and import it into Garmin Connect.
Pity that Garmin can't combine the functionality of Basecamp and Connect
Posted : 16/07/2012 2:00 pm
