Cutting a steel sea...
[Closed] Cutting a steel seatpost out of an aluminium frame
[#2923603]
Anyone done it?
How time consuming was it and how easy is it to damage the frame?
Last resort time. Chemicals and brute force aren't shifting this bugger.
Posted : 07/07/2011 6:04 pm
Ive done ally out of Ti*.
Took a while and was fiddly as ****. But worked in the end.
Used a hacksaw blade bolted into a baton of wood.
* there's actually an Al insert in the seattube on that Ti frame, so post and insert had bonded. It also meant that I had to be very carefully at the seat collar end as I couldnt rely on the hardness of Ti to shrug off any clumsy sawing strokes.
Posted : 07/07/2011 6:25 pm
Cut just above the top of the seat tube and cut down the inside of the seatpost with a hacksaw blade. Don't blame me if it all goes horribly wrong though.
Posted : 07/07/2011 6:26 pm
Thanks.
I'll start it with my powered hack saw then thread up a normal one and finish it by hand.
Full susser with short seat tube.
Posted : 07/07/2011 6:37 pm
Have you tried the hot air gun on the frame and ice in the seat tube approach?
Posted : 07/07/2011 6:39 pm
maybe unfasted the seat clamp first 😉
Posted : 07/07/2011 6:55 pm
Boiling water, PlusGas, enough force to break the seat clamp and swearing. None of which have shifted the bleeder.
Posted : 07/07/2011 7:02 pm
You did try undoing the seat clamp didn't you...
Just Kkidding.
Is it turning at all ?
Stilson might get it turning.
Posted : 07/07/2011 7:04 pm
Don't do it - look for some old school engineering workshop local if possible - try getting it reamed out - and you may still have a usable frame afterwards.
Posted : 07/07/2011 7:22 pm
hot air gun for more heat? You will hve to be very careful to cut it out without damage to the frame
Posted : 07/07/2011 8:11 pm
Had a word with one of "the wise men" on our factory floor.
For the price of 8 cans of lager they are going to weaken the post by grinding away at it from the inside then crush it with a set of grips and pull it out. The scary looking (in an industrial dentistry sort of way) cutting tools will not come into contact with the frame.
Saves me a lot of trouble.
Posted : 08/07/2011 4:46 pm
make sure they drink the lager afterwards 😆
Posted : 08/07/2011 4:52 pm
