the angle grinder slipped, my frame is in bits............. 😀
Been following this with interest. Got my own frame that I'm going to be building up, though the extent of my bodging will be adding a Wolf Tooth boostinator and re-dishing the rear wheel.
All the best with the build and make sure you post pics when you're done (assuming the angle grinder doesn't slip again..!)
will certainly put some pictures up 🙂 I am thinking of putting something like this underneath the seat clamp, think it will stretch to 34.9mm?
Bike is finally finished 🙂 delighted with how it rides as well, pedals uphill much better than i thought it would with the 160mm fork and the offset bushings bringing the head angle down to somewhere between 65.5 - 66. Well impressed with the manitou mattoc pro 2, super plush,light with loads of adjustments. Still trying to figure out best shock setup but its running well so far.
Trying to set it up for riding without a backpack as well so ive put the syncros matchbox waterbottle cage on. Really slick piece of kit.
