Current Short Trave...
[Closed] Current Short Travel Forks
[#11396828]
So I'm looking to get a 130mm 29er (boost) fork at the end of October for a bike build.
With supplies being what they are, and budget being a bit limited, what other choices have I not covered below?
Keeping it below £600, I've got the following options:
Pike Select should just sneak in around £600
https://www.bike-discount.de/en/buy/rockshox-pike-select-rc-29-debonair-tapered-boost-953033
Alternative: SR Suntour Axon is around £450 (always wanted to try the higher end Suntour).
https://www.starbike.com/en/sr-suntour-axon34-boost-29er-27.5-suspension-fork-130mm-tapered-black-matt-15mm-rlrc-pcs/
The other option is converting my Yari to a Charger 2.1 and getting a 130mm air spring. Could get this done as part of a service.
For reference, the bike will be a Banshee Phantom V3. Just looking for some opinions really.
Posted : 24/09/2020 1:21 pm
I would give TF Tuned a call and see what the upgrade options are for your Yari. Something like the Yari UP and debonair air shaft might be a good upgrade and will be cheaper than a new fork.
Posted : 24/09/2020 1:29 pm
Christ, was expecting a thread lamenting the lack of 80 mm forks on the market.
Posted : 24/09/2020 1:38 pm
I have a Lyrik set to 130mm on my hardtail because I already had it and converting was the cost effective option. It is quite a lump of fork and I can't help thinking I'd rather something a little lighter on a short travel bike like the Phantom.
Posted : 24/09/2020 1:43 pm
Haha, I should have put (in the grand scheme) in the title!
I had been considering a Yari Up before. It's a 2020 Yari so already has the Debonair spring (massive improvement I found over the old one). Just need to drop the travel with a new one.
Could be a good shout as it'll probably turn out cheaper than a new fork (and possibly better).
I get what your saying about the weight. I considered it, but I'm not exactly a featherweight so I probably won't notice a couple hundred grams? Also the Yari would be stiffer I suppose.
Posted : 24/09/2020 1:46 pm
 5lab
aren't sids good for this?
https://www.bike24.com/p2374439.html?q=sid
Posted : 24/09/2020 1:54 pm
Only 120mm travel though SID. I would have considered it though to be honest.
Posted : 24/09/2020 2:01 pm
 5lab
true, a full pound lighter than a yari, though
Posted : 24/09/2020 2:02 pm
Marzocchi Z2
Posted : 24/09/2020 3:59 pm
Depending on exact spec, you don't need to push your budget too much more to get a pike ultimate from StarBike.
Just got a Lyrik from them and the service was top notch.
Posted : 24/09/2020 4:07 pm
@cloggy
I was keen on a Z2, but there doesn't seem to be much stock about 🙁
@onzadog
I was trying to be more sensible for a change, but I reckon if I try hard I could stretch to a Pike Ultimate.
Either offset on the forks would be fine according to a guy who tested the Phantom (he actually erred towards a 51mm offset).
Posted : 24/09/2020 4:58 pm
Chain Reaction have them
Posted : 24/09/2020 5:24 pm
So they do! £550 for the one I want. Bet they sell out the day before I order though!
Posted : 24/09/2020 5:47 pm
Unfortunately you missed out on the bargain DT Swiss F535 fork on Wiggle test rode mine on the Ripley other day a very good performing fork
Posted : 24/09/2020 5:51 pm
I got mine from Chain. Just for durability.
Posted : 24/09/2020 5:59 pm
Yeah I was gutted as the DT Swiss would have been great at those prices!
Z2 is on the cards now, but they are a bit weighty! Might not matter though to be fair.
Posted : 24/09/2020 6:33 pm
Actually, I think the weight on Chain Reaction is wrong. Looks like they might have published the weight of the coil version.
Think I'm going for the Z2.
Edit* Found a brand new Fox 34 on eBay for £400, so snapped it up quick! It's the same one I had on my Intense so I know them pretty well.
Posted : 24/09/2020 7:48 pm
