Cube Stereo main pi...
[Closed] Cube Stereo main pivot bolt needed, can you help?!
[#11195514]
Evening folks, asking for a mate who's looking unsuccessfully for a main pivot bolt to replace the sheared one on his 2016 Cube Race Stereo 140.
Can the hive mind help find one?
Thanks in advance.
Posted : 16/05/2020 9:27 pm
https://www.infinitycycles.co.uk may be able to help.
Posted : 16/05/2020 9:51 pm
According to this:
The part number is: 10527 if its an alu frame, or 10502 for the carbon.
10527: https://www.bike24.com/p2185408.html
10502: https://www.infinitycycles.co.uk/17603/products/cube-bearing-set-stereo-2017-ams-main-pivot.aspx
Both with bearings included.
Hope this helps.
Posted : 16/05/2020 11:02 pm
Make sure you put plenty of blue thread lock on and importantly let it cure before riding! Those bolts are notorious for backing out!
Edit: That means you'll also have to chase out (use a pick/tap whatever) any of the old dried stuff out of the threads in the frame (if there is any) so it bonds properly.
Posted : 16/05/2020 11:55 pm
Windy, Ginger and Chester, thanks a lot. Really helpful. Best to you all.
Posted : 17/05/2020 7:26 am
@giantonagiant
Just out of interest how/why did the bolt shear?
Posted : 17/05/2020 4:51 pm
