I have a Stumpjumper HT Carbon frame and the downtube is very wide and flat underneath. Crud Catchers seem to have a centre section made to fit a round tube.
Will this fit my frame or is there something better? Thanks
Same problem here, so I run one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=25797 ]these[/url].
Design and make your own
M.T.F.U. and just get muddy - problem solved ! ;0)
If the downtube is that wide, why do you need a crud catcher? Just let the tube shield you
Try one of these? http://www.charliethebikemonger.com/userimages/procart16.htm
what you doing riding your tupperware bike in the wet anyway? It could melt 😉
Big downtube does stop a lot of mud. Got a shock blade which is quite a good bit of kit, will see how it goes! Thanks
