Right I've got a 2010 crossmax sx front wheel currently running in 20mm guise can it be converted to 15mm or is it 20mm/qr only ?
or is it the 2011 sx' that can be changed between all three standards.
I thought they changed the hubs in 2009/10, can you pull a 20mm adaptor out of your hubs? should come out fairly easy if u can, only held in place by an recessed O-ring on the adaptor.
yep you can just pull the 20mm adapters of but can I get 15 mm adapters to replace them .looked on crc and no joy.
Get your LBS to contact mavic directly, I would of though that u should be able to get the adaptors separately.
Or put a wanted ad up for some
If they are white hubs you are in with a chance. I got a set of adaptors off Fleabay for £8.
Winstanley's list them on their website; but as above, any Mavic dealer should be able to get a set.
[url= http://singletrackworld.com/forum/topic/crossmax-15mm-adaptors-where-to-buy ]Yes[/url]
The postage price is a mistake, if you email them they'll send em a lot cheaper, I got some and they turned up ok and fitted fine...
OK might have to just see if I can find some and hope they fit.
only thing is mines the 2010 grey hub, slim chance or " no chance " ?
thank for the replys. 🙂
