Just tried to fit my RR evo kevlar tyres on my crossmax sl wheels and i just cant get the buggers on the wheel - has anyone has a similar problem fitting tyres to these wheels and if so any hints or tips?
.......its doin' ma tits in!!!! 😈
i have the same tyre/wheel combo and never have any problems 🙂
But you can try and put the tyre in the muddle/center chanel of the rim then that will give you more slack at the opposit side... hope this makes sence?
also make sure you fit the side nearest the valve last, this means that the tyre on the opposite side has got the channel in the middle of the rim to go into
Similar. DT5.1 rims and bonty rubber. Impossible.
I've had nightmares with Nobby Nics and Traversees. Same tyres, different wheels, and visa versa - no problem
............still no luck guys 😥
My Spesh Sauserwinds (2Bliss so can be used tubeless) have firm sidewalls and are hideous to get off.
Nothing more humiliating than being defeated by a simple tyre! I just use more tyre levers if it's tough to get off. Up to five sometimes!
washing up liquid.
I had the same nightmare with my conti trainer tyre on my roadie wheel & somebody said (wait for it) put it on a radiator to soften the rubber. I thought they were winding me up..... I tried it. Job Done!!
whaddya know........the fairy liquid did the trick (eventually!)
cheers for the help guys 😛
