I'm 5' 11" so assume a 56cm is the size I want?
On a 56cm frame, can anyone tell me the distance from centre of BB to centre of fork dropouts? I need to make sure I could run mudguards without any toe overlap & I'll be building it up with current parts rather than getting a full build (which means using 175mm cranks).
Thanks
Posted : 10/03/2012 1:55 pm
Anyone with a CDF here tonight?
Posted : 10/03/2012 7:37 pm
Yeah I'd say 56 sounds about right. I'm 6'1 with a 58 Croix De Fer and am at the "lower middle" end of its range. But try first if you can.
Posted : 10/03/2012 7:41 pm
