can you fit a 2.35 tyre on a stans ZTR crest rim ?
Yes, no problem at all
I was told no at a bike shop as its a lighter wheel for smaller tyres, on the rim it says 2.2 but i'm sure a 2.35 would be fine ?
Crests aren't even that narrow. They're wider inside than an Arch I know people who use 2.5 DH tyres on Arches.
2.35 on a Crest will be absolutely fine and your shop is wrong.
The internal dimension is only 1.6mm smaller than the Flow rim. I've had no issues with a 2.35" Nevegal SWS (not UST) running tubeless. Kendas actually measure the stated size too, so you should be fine.
I see thanks for you help guys put my mind at rest 🙂 🙂
No worries
Just had a look at the stickers on my rims (I have an Arch and a pair of Crests). Anyway, the Crest pressure recommendations only go up to 2.2, so that could the source of your bike shop's assumption. Looking at the (narrower) Arch the pressure recommendations go up to 2.3", so figure an assumption from that!
a 2.35 high roller for instance isnt very high volume and would be fine no matter what the spec says ime.
crests are no downhill rim though if thats what your after, im just trying to paint a picture
