Creeping seatpost
[Closed] Creeping seatpost
[#1619625]
It's the right size and so is the Hope QR but no matter how tight I do the thing up it creeps down and inch or so over a ride. Ideas on how to stop it would be welcome, can't shim it as there is no room. Need a QR as I often pop the seat off for transporting the bike.
Posted : 18/05/2010 12:09 pm
Carbon assembly paste.
Posted : 18/05/2010 12:11 pm
I had one of these... a Thomson that slipped down whichever frame I put it in. I successfully sorted in in a two stage process.
Stage 1 : I bought some of that carbon "grease" that folk with expensive frames and seat posts use so the two carbon faces get some friction. This slowed the process down quite a bit but not entirely.
Stage 2 : I got a different frame and now it is as solid as a rock.
(The new frame was incidental BTW. I had fitted the post to 5 different frames before the last one. I was at the stage of chucking the damn thing away if it has continued slipping!)
Posted : 18/05/2010 12:15 pm
 lrd
I don't really like the Hope QR, prefer Salsa's which has fixed a slipping post for me before.
Posted : 18/05/2010 12:22 pm
Are you a regular seatopst dropper? If so, you could have worn the inside of the seattube slightly.
Or, you could have 'overlapping' manufacturing tolerances, so you've a slightly oversize seattube and a slightly undersize seatpost.
Is it a 27.2 post? Ragley are making some 27.3 posts for just such a problem.
Posted : 18/05/2010 12:25 pm
 tron
I've found a difference between different QRs. The identiti (or one of the many ones with someone else's name on) ones work for me.
I had the same problem with a Thomson post and a Hope QR.
I went back to the original Giant QR and problem solved.
It sounds like Hope QR's can be a bit prone to this.
Posted : 18/05/2010 12:26 pm
 tang
thomson, salsa, cotic soul = slip from time to time here. might try the carbon paste or do a thin shim if i get round to it.
Posted : 18/05/2010 12:29 pm
I too have had a few problems with the Hope QR collar.
The best one has been the Pace but it was not QR so a bit of a pain at times.
I think the squeeking annoys others and not me, the slippage is a problem.
Do you adjust your position regularly? If not, hows about a water soluable bonding solution?
Posted : 18/05/2010 12:33 pm
i had this with different QRs too. Got some carbon assembly paste on the seatpost, and also put a little bit between the outside of the frame and the clamp itself. This has worked nicely and requires lots less force to close.
Also make sure the cam etc are nice and clean - maybe a spot of grease or coppaslip on them.
Posted : 18/05/2010 12:34 pm
My QR has a curved plastic washer under the QR arm, and this has cracked. The result is that the post has now started slipping. I'm in the market for a new QR, people seem to get on with the Salsa one, so it might be worth checking that the QR itself hasn't failed.
Posted : 18/05/2010 12:35 pm
FWIW my Salsa one made not a jot of difference.
Posted : 18/05/2010 2:19 pm
Sometimes the tension is actually slacker when the QR is fully whacked up - i.e you have gone beyond the high point on the cam. Try backing off a little from fully locked and see if that works.
Posted : 18/05/2010 2:32 pm
Thanks guys will have a play about. Ta. Think the carbon stuff sounds like a plan as the thing is on so tight I can barely get it done up even with a bit of grease on the cam.
Posted : 18/05/2010 2:44 pm
I've had exactly the same problem with Hope seat clamps on various combinations of seatpost/frame. I think it's because of the smaller M4 bolt that Hope use compared to some which use an M5 which you can do up tighter. Hope + oversized frame or undersized post = slippage.
Fixed it on my current full susser by swapping the Hope for an M5 bolt one. FWIW, bolted ones tend to do up tighter than QR.
Posted : 18/05/2010 2:49 pm
Carbon grease / paste works on my Orange 5 post.
Posted : 18/05/2010 2:53 pm
 SiB
+1 for carbon grease.
clean the QR.
Posted : 18/05/2010 2:54 pm
Erm
sellotape, round the seat post, non slip surface, easily replaced , cheap but to be fair not as cool as non-slip carbon friction paste.
Posted : 18/05/2010 3:20 pm
+1
Posted : 18/05/2010 3:37 pm
