Cree XML Light - Re...
[Closed] Cree XML Light - Replacement rubber rings?
[#4573366]
Hi, I have 2 of these and have lost all of the damm rubber rings. Anyone know where to get replacements from (Or ghetto alternatives)
Posted : 19/11/2012 9:20 pm
standard O rings are what i use, you want one about 50mm diameter. loads on ebay
Posted : 19/11/2012 9:23 pm
Piece of innertube works as a quick fix just need to experiment with the size for the optimum grip
Posted : 19/11/2012 9:24 pm
tomfun - I've got plenty of silicon o-rings for mounting lights (silicon is better than nitrile for outdoor use).
You can have a couple of each size - email me your details. No charge - just drop a couple of quid in a mountain rescue tin next time you see one.
Posted : 19/11/2012 9:28 pm
Cheers for the help folks.
Neninja - thanks very much for the kind offer, i'm very good at losing these so for the sake of a couple of quid i'll get the 25pk from ebay.
I'll still chuck some funds in the Mountain rescue tin next time i pass one 😉
Posted : 19/11/2012 9:56 pm
Those Ebay ones are only 3mm - that's really thin. You really want 5mm thick o-rings.
http://www.ebay.co.uk/itm/METRIC-NITRILE-RUBBER-O-RINGS-5MM-DIAMETER-VARIOUS-SIZES-FROM-33MM-ID-TO-62MM-ID-/221123038545?pt=LH_DefaultDomain_3&var=520109102911&hash=item337bf5cd51
Posted : 20/11/2012 12:57 am
