So does a 18650 fit and work then? I would think it would rattle about but know now't about 18650's
I did a test last night. These lights: http://www.ebay.co.uk/itm/130804284439
I compared freshly charged 850mAh AAA Ni-MH with the supplied alkaline AAAs. The NiMH cells were about 10-20% brighter on high beam. This is likely because of their lower internal resistance resulting in less voltage drop under load than the alkalines. 'Branded' alkalines such as Duracell might be better.
You need an extension tube to fit an 18650, the same eBay supplier as the lights above stocks them.
So can I use Duracell AA 2450mah batteries with an extension ring in my 18650 torch?
Rather than burning the house down with the Ultafires.
If so what difference can I expect
So to save me trawling all over the forum whats the best 18650 alternative to this Aldi torch or is the above linked twin ebay set the best it gets?
Well the 18650 battery fits the torch fine. Its narrower than the barrel but when the end cap is screwed on it doesn't seem to wobble, wouldn't be hard to stick a little foam in there as padding if using it on the bike.
I have now put the batteries on charge, and will be checking them every few minutes to check they don't live up to the 'fire' in their name. They do say protected on the auction and the batteries, but hey, this is ebay so who knows!
spooky, which ones are these then that fit the 18650, got a link?
I paid £9.99, he then ramped the price up to £13.99 seconds later, its now at £23.99 but there is still the 'make an offer' box so I might still be worth a punt. Not at the full price though, obviously!
FWIW i purchase two lamps for my lads bikes - very similar cree job and they are great for the money.
I run senybor rechargeables, the single (blue) 18650; we'er in out 3rd season and still going strong, no probs at all. I always recharge immediately post ride, never leave them half used/charged. That goes for all batteries tbh, esp Li-ion.
In case anyone's interested:
http://singletrackworld.com/forum/topic/fs-18650-battery-3
Also, I tried the inner tube helmet mount without success so here's my new and improved version.
You need a 7-8" strip of MTB inner tube and another 2" strip.
Cut a section out of the the long strip so that there are two rings on either end joined by a single-ply sheath.
Put the short piece over the handle of the torch for helmet protection and mounting stability, and loop one of the rings over the head of the torch.
Push the other ringed end of the strip down through a vent and up through the one behind...
then loop the ring over the head again. It locks the beam focus on the widest setting but its probably best like that anyway.
Ain't going nowhere.
Jimmy.
That's genius.
Can I nick this?
Yes Xtar's are fine as are Callies Kustoms, genuine Sanyo / Samsung or unprotected Panasonic NCR18650B's (which the majority are based off)
I use AW 2900's & 3100's and Eagletac 3400's and have never had any bother with them.
I charge them to 3.75v - 3.8v (40% charge) and bung them in the fridge when not in use ( I have loads of them )
My AW's are quite old now and are still going strong.
Thanks, I'm happy with it!
Nick it? Its on a public forum, go for it. Unless you're going to make millions then i want a slice...!
Wrong thing to do with 18650's. you need them stored with 40% charge not 100%
Charge fully before use then re-store at 40%
http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
You're a pal.
I bought 2 of these the other day and struggled to fit one on my helmet last night.
Been thinking all day about how to do it, and then this pops up.
TPOSTW!
Like the idea of a light with a health warning.
Any ideas on how to waterproof, Vaseline used to b used on seals.
Looks like the ring on the front holding the lens in needs locking, locite?
How's about this one!
900 lumens, 3 aaa batteries.....
Any thoughts?
...900 lumens (from) 3 aaa batteries.....
Any thoughts?
900 lumens my arse.
It will be bright though.
My issue is with lenses; having gone through smarts, cat eyes and now magic shine for mainly commuting on old railway tracks, I want a focused beam. The magicshines pee light out everywhere, I cannot afford the high end stuff.
So, power is good, but if the lens/reflector is good like a pretzel head torch then it's all good.
Any links to custom reflector/lens stuff?
That would be my choice.
[url= http://budgetlightforum.com/node/12384 ]Battery wise[/url] I would say its better than the 18650. Its got an XML T6 so brightness wise it should be OK and the bonus is that the 900 lumen output has a lower lie-factor than other single XML lights rated at 1800+ lumens.
I've not had a convex lens zoom torch so I can't compare with a reflector but I would be interested in the comparison if anyonone's had both.
For anyone interested I found an extension end cap that will allow the aldi torch to use a 18650 battery.
[url= http://www.ebay.co.uk/itm/CREE-Q5-Bicycle-Bike-Cycle-Led-Head-Light-Front-Light-/200715786855?pt=UK_SportsLeisure_Cycling_Bike_Lights&var=500091554978&hash=item2ebb97da67 ]Here...[/url]
Or also available from my link above without dodgy 18650 battery and charger...
I got an extension ring for the Aldi light and rand the torch with a 18650 battery in. It managed 3hrs before fading and was still going after 3 and half hours. Not bad and perfect for a commute.
I managed 2 hrs with the supplied batteries and they are still going strong.
#Edit - I forgot to say: I didnt buy the Aldi one. 3xAAAs either wont be as bright or last as long as an 18650. I've got a few over the years: this is the most recent incl 2 batts and charger and adapter (that runs cool) all for £11-http://www.ebay.co.uk/itm/290778308356?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Based on the recommendation by couldashouldawoulda (cheers!) above I ordered one of the torches linked to above and it's just arrived. I'm charging the batteries now and have only had out of the packet for 5 mins but a quick check it worked and I reckon I've got my £11 worth.
Ive had the above torch for a good few mounths now and was wondering if there is a wide lense for the torch ?
I ordered a [url= http://singletrackworld.com/forum/topic/cree-light-at-aldi/page/2#post-4391766 ]couldashouldawoulda's recommended torch[/url] on the 23rd of November - it's just arrived today! Coincidentally today is the day the seller has refunded my money for non-delivery...
However one of the batteries looks a little unhealthy to say the least!
On the plus side, the batteries that have been supplied are 4200mAh rather than 2400mAh.
Not sure if you're being serious or not!
If not, there is no such thing as a 4200mAh 18650, if that picture is the battery which has 4200 on it, then you'll be lucky if it has 500mAh in it, but I would recommend just throwing that thing away and buying decent battery's.
I [i]was[/i] being serious when I wrote it, but a bit of Googling in the meantime has shown that 3400mAh seems but be about tops and that's only on (what appear to be) [url= http://www.torchdirect.co.uk/batteries-and-chargers/xtar-18650-37v-3400mah-li-ion-protected-battery.html ]quality batteries[/url].
Think I'll grab a pair of [url= http://www.ebay.co.uk/itm/2pcs-XTAR-18700-18650-2600mAh-Lithium-Battery-UK-Location-shipping-/250969568148?pt=UK_Sound_Vision_Battery_Chargers&hash=item3a6ef3b394 ]Xtar 2600mAhs[/url], unless anyone can recommend something else?
On another note, the bundled charger has 2 flat (US/Japanese-style) prongs on it and a UK adaptor. Does it matter which way around the prongs go into the adaptor - one live and one neutral etc?
If you're using the light as your only light, then protected battery's are not the way to go as they will just shut the light off without warning.
Better to get non-protected and understand when to change the battery yourself, usually its around 60 mins with an XM-L light on high.
The chargers will/should work any way around.
Homebase are selling something that is very similar for 6 quid. The light out put is damn near identical and thats with duracells in the aldi and cheapies that the homebase one came with.
Just remembered. The homebase one is a Rolson so maybe else where as wwell. Red
@lightman: Thanks for the info re:protected/unprotected batteries, definitely worth knowing.
I used the torch on the road last night with the 1 good battery. I was out for 2.5hrs and used it 60% medium (unlit country roads) 30% low (street-lit towns) and 10% high (fast downhill sections on unlit country roads).
When I got back I ran it on high for about 5mins seeing how much of the neighbourhood I could light up and it was still going strong.
Even after waiting 6 weeks for it to be delivered [b]and[/b] with one duff battery [b]and[/b] one optimistically labelled battery I'm pretty pleased with what I've got for UNDER ELEVEN POUNDS!
