Creaky full suss - ...
[Closed] Creaky full suss - stumpy
[#2670803]
I have a 2010 spesh stumpy. And when im on the flat or gentle uphill when i put power down i get a creaking noise, Without stripping anything down i have checked the bike over as best i can and found nothing wrong.
Before i go to town on it is this a common occurance or should i be concerned.
cheers
Posted : 17/04/2011 10:02 pm
Seat post in tube? Not an uncommon reason as far as I'm aware.
Posted : 17/04/2011 10:16 pm
Do up all your QRs - really tight
Had a creak on my Trance which I couldn't trace, my LBS just did up the QRs, problem solved.
Posted : 17/04/2011 10:50 pm
 mrmo
have you checked the bottom bracket, is the creak fairly constant as to when though the pedal stroke?
Posted : 17/04/2011 10:52 pm
Suspension pivots. As you pedal a little bit of "bob" can cause a creake.
Posted : 17/04/2011 11:05 pm
See if it creaks when you lock out the suspension. If not, it's the pivots.
Posted : 17/04/2011 11:08 pm
