Creaking Thomson dr...
[Closed] Creaking Thomson dropper
[#9575182]
Was out riding last night, along the canal to start and my seatpost was creaking like a good Un. I pinched the seat collar with no difference. What did make a temporary difference through the evening was dropping the post and re-raising. But then the creaking kept returning. Any ideas what's happening? And what's to service with a Thomson dropper?
Posted : 28/09/2017 7:33 am
Sounds like the keyways/bushings are dry. Biggest frustration with the Thomson is that it's a factory service only. Done under warranty within the first two years. I'm not looking forward to getting past that point though.
Posted : 28/09/2017 7:55 am
I had a 27.2 version that did exactly this. Eventually it failed completely and was replaced under warranty.
Posted : 28/09/2017 7:59 am
Ah shit. So does it need to go back to the distributor?
Posted : 28/09/2017 8:23 am
Yep, iride is the only place in the uk to get it done.
I wish there were parts ans tools for a simple sliding element service. I could live with the cartridge being factory only but this is just silly.
Posted : 28/09/2017 8:48 am
Is it losing height on its own? Mine did that too before the complete failure.
You could try tweaking the cable tension, as Thomsons are pretty sensitive to this, but I don't reckon that will solve your problem.
Posted : 28/09/2017 8:49 am
Before you do that, i found I was getting creaking from saddle clamp/rails - maybe try that first?
The saddle is creaking, but this is different - sounds a lot more internal and is temporarily resolved with a drop / raise.
Just found the iride site. Cheers.
Posted : 28/09/2017 8:55 am
They may ask you to go back through the retailer.
Posted : 28/09/2017 9:23 am
