Creaking Ks 950 sup...
[Closed] Creaking Ks 950 supernatural
[#3607053]
6 " version got it at christmas really like it but it has started creaking can't decide if its the clamp or the post itself. Have regreased the bolts and the clamp but it is still there. It did about 3 creak free rides, is this normal (it's annoying) or fixable ?
Posted : 25/01/2012 2:22 pm
Maybe try opening up and regreasing the insides as per the instructions?
Posted : 25/01/2012 2:29 pm
did'nt get any instructions and is that necessary every 3 rides.
Posted : 25/01/2012 2:31 pm
Probably not every 3 rides normally, but if its been a bit wet out and/or if they don't put a lot of grease in from new then it wouldn't hurt to try in case it does sort it
Else, send it back
Posted : 25/01/2012 9:54 pm
You sure it's not creaking from between the post and the frame?
My KS does this when the grease in the seat tube dries out/gets washed out.
Posted : 25/01/2012 10:12 pm
will do both and see what happens, got some instructions of their website did'nt realise you could alter the rebound speed aswell, cheers
Posted : 25/01/2012 10:50 pm
My saddle is the creaky bit. SDG Belair creaks more than my knees...
Posted : 25/01/2012 10:54 pm
Mine creaks like mad if I over tighten the seatclamp bolts, had go put up with it all the way round the xc route at Inners once.
Posted : 25/01/2012 11:53 pm
Most likely just regular seatpost/saddle creakiness so forget that it's a dropper and tackle it like you would any other seatpost
Posted : 26/01/2012 12:34 am
