Cranks for Rohloff
[Closed] Cranks for Rohloff
[#463312]
I'm planning my Rohloff build and looking for cranks. I was hoping to use track cranks because then I can use a decent square taper BB but the chainline is only 42mm and the Rohloff needs 54mm which would mean a very long BB spindle.
So, mtb cranks looks like the way to go using just the outside ring.
Suggestions?
Ta
Posted : 10/04/2009 5:30 pm
I use a XT Hollowtech II with the 38T chain ring in the outer position (where the big ring would be).
This seems to be a fairly standard set up amongst the Rohloff users, who'll be along shortly. Works fine, except for the short'ish life from the Hollowtech bearings.....well documented here.
Posted : 10/04/2009 5:43 pm
Middleburn cranks with one of their 38T dh ring on the outer.
Posted : 10/04/2009 5:49 pm
Middleburn outer ring position on a dual or triple spider will give you a 54mm chainline. However, a number of smaller chainrings will not fit behind the crank arm on the 5-arm spider. A downhill middleburn ring with the notch cut out at the right place will be best.
I use a 36t middleburn standard ring and that just fits. A hardcoat ring wont fit though - too thick. I havent tried a 4-arm yet.
Middleburn chainlines work with 113mm BBs although some have said that for a 73mm shell a 115mm BB is better for the extra little clearance you may need.
Yebbut, the Middleburn DH rings are fugly.
Posted : 10/04/2009 6:29 pm
the larger diameter ones are a bit fugly I agree.
36T I think looks OK since the depth of the plate is so much shallower.
You can of course always file a rebate away in any preferred chainring if it doest quite fit behind the crank arm in the outer position - it wouldnt need much material removal, it is a very close miss.
Posted : 10/04/2009 6:32 pm
I don't think they're fugly, fdirty, but not fugly!
Posted : 10/04/2009 6:35 pm
that would look so much better if the ring was in the outer position snaps! 🙂 but we've already had this argument... 😉
Posted : 10/04/2009 6:37 pm
Nah the ring looks to large, I think the spider breaks it up nicely, I might fit one of the different colour spiders if I get bored this weekend.
Posted : 10/04/2009 6:40 pm
