Crank Spline fix wi...
[Closed] Crank Spline fix with toothpaste tube slither
[#4042084]
I thought this is worth a mention and apologies if its in the wrong forum
I had 'dead' spots when pedaling at the top of the pedal stroke on each side and yup it turned out my Race Face Evolve crank splines weren't tight anymore. I could play them by holding them and moving in opposing directions
Just before I was going to spend £125 on new SLX cranks a friend told me if I jam a slither of toothpaste tube and persuade the cranks to go back together it would work and YES it did 🙂
Saved me £125 and if I have to re-do it every month or two then so what
I have heard a Coke can slither would work too and be more durable
Anyway I'm passing this on in case it saves someone else quite a bit of dosh
Posted : 06/06/2012 12:31 pm
