Crank Removal Probl...
[Closed] Crank Removal Problems -XTR M970
[#5698658]
Trying to remove my M970 cranks.
Non-drive side arm won't budge. I am am using the correct tool, which is now stuck on the axle. Not cross threaded as I wound it on carefully by hand before applying any leverage.
I have also tried heating the area to no avail.
Any suggestions?
Posted : 17/11/2013 12:20 pm
Bigger 8mm Allen key in the tool.
Posted : 17/11/2013 12:22 pm
I have bent the biggest Allen keys I can get in the whole
Posted : 17/11/2013 12:23 pm
Stick an old handlebar on the end of one to get extra leverage. Never seen one of those be problematic.
Posted : 17/11/2013 12:25 pm
I'm in Stroud you you want a look!
Posted : 17/11/2013 12:26 pm
remove tool and ride around the block with no bolt in and see if it loosens the arm on the splines?
Tool is stuck in the axle as I stated above.
Posted : 17/11/2013 12:29 pm
Just broken an Allen key using the handlebar trick
Posted : 17/11/2013 12:32 pm
Bit confused as the tool threads into the inside of the crank arm rather than the axle
Could you try to slightly tighten the 8 mm Allen key then remove the tool once some of the tension is off it
Posted : 17/11/2013 12:41 pm
Yeah tool threads into the LH crank arm, the alu bolt threads into the axle.
Posted : 17/11/2013 12:44 pm
[url= http://www.chainreactioncycles.com/shimano-xtr-left-hand-crank-removal-tool-m970/rp-prod25630 ]Should be this tool[/url]
screws into the crank arm, then you undo the bolt acts as a puller, usually very simple to do 😀
The pins are to unscrew the plastic insert which keeps the threads clean.
Posted : 17/11/2013 12:46 pm
doesn't the tool have a reverse thread on it - you are undoing it the right way?
Posted : 17/11/2013 12:49 pm
This happened to me once. Can be a bugger to get out. I think i ended putting the crank in a chunky vice at work and using a massive pipe wrench which was a tricky procedure. As you've discovered, with the small hole in the tool you can't get a big enough screwdriver/allen key through to generate the leverage.
I had managed to get the crank off already, just had the tool stuck. I also replaced the bolt as that had deformed being so soft.
Best of luck!
Posted : 17/11/2013 12:54 pm
Sussed the problem now, need to get the tool out somehow now
Posted : 17/11/2013 12:58 pm
LH thread on the tool. Stick a small Allen key in the hole on the side to help turn it if necessary.
Posted : 17/11/2013 1:07 pm
 rob2
I find these a bugger to take off. I just knock the crank arm off with a rubber mallet now. Even following the you tube video mine never feel happy with the extractor bolt
Posted : 17/11/2013 1:10 pm
All sorted now, thanks guys
Posted : 17/11/2013 1:28 pm
