Crank removal allen...
[Closed] Crank removal allen key size?
[#5964702]
Am i right that i need a 19mm allenkey to remove this? ...how about the allen bolt/nut after ? Its a SRAM crankset. Cheers
[URL= http://i1073.photobucket.com/albums/w396/wolfenstein782000/Mobile%20Uploads/20140216_113241_zpsx9l6tnd8.jp g" target="_blank">http://i1073.photobucket.com/albums/w396/wolfenstein782000/Mobile%20Uploads/20140216_113241_zpsx9l6tnd8.jp g"/> [/IMG][/URL]
Posted : 16/02/2014 1:29 pm
Dont forget the edges will likely be beveled. ?. Usually its an 8mm key afaik.... isnt the hole in the middle where the key fits and not the big one?
Posted : 16/02/2014 1:34 pm
I think the big one kinda protect the inner one coming loose. .. Like the other sram crank i deal before... This one is the super size of that for some reason
To be honest i don't know how to remove the inner nut/bolt yet till i remove this big one.
Posted : 16/02/2014 1:42 pm
Here you go ignore his fancy tools though.
Posted : 16/02/2014 1:44 pm
You don't need to touch the large bolt, that just holds the self extracting bolt into the crank arm. I believe its an 8mm key for the inner one. Older ones were a 10mm IIRC.
When you do it up again, it needs to be REALLY tight.
You're measuring it the wrong way. Go across the flats rather than corner to corner.
Bit hard to tell from your pic, but if you've got a smaller hex bolt inside, that's the one you want to undo. It's usually 8 or 10mm
Leave the larger one where it is, it's so that the crank pulls itself off the axle when you unscrew it. Also they are sometimes LH threaded and alu, so easy to round off if you aren't careful. just undo the inner one.
I've never played with SRAM cranks, but Allen keys are measured across the flats. It looks like you're measuring corner to corner.
Hth
Edit
What they ^ said.
Posted : 16/02/2014 1:47 pm
@drac. Youre a star!
Cheers all. And thanks for pointing out how to measure allen nut.
Duh ! Felt so dumb now. Well, there are always something learn everyday 🙂
Thanks again chaps
Posted : 16/02/2014 1:51 pm
