Crank recommendatio...
[Closed] Crank recommendations?
[#6952706]
Hi
I'm after some new/second hand cranks. Currently running shimano XT which my son will have.
I'm running single oval ring, threaded bb.
I would like them to be light, black. Not to expensive.
Thanks in advance.
Posted : 24/03/2015 10:00 am
TBH I'd struggle to see much past SLX, maybe not black like the new XT but like all black cranksets (I've two different ones in the garage) it rubs off...
If you still want one, what kind of price range are you looking at? (I know you say new/2nd hand.. but that could still mean anything)
Posted : 24/03/2015 10:19 am
Around £100??
I generally don't rub my cranks as I use spd not flats.
Posted : 24/03/2015 10:35 am
The difficulty with cranks is that Shimano are soooo good, that recommending alternatives is always tricky as they are either heavier and/or more expensive.
So XT would always be my first choice.
If you like the look of a direct mount ring, then Race Face Turbine Cinch might do the job.
There were also some XX1 cranks cheap on the on-one site, but I can't remember what the restrictions were now, or even if they ran out. There's a thread from a couple of weeks ago.
Posted : 24/03/2015 10:50 am
I'll take a look.
Thank you.
Posted : 24/03/2015 10:57 am
Shimano XT are difficult to beat! You'll have to spend a lot more to get anything slightly better.
Beware of different bcd size though for your existing chainring and consider if you want to move to the world of GXP bottom brackets.
Posted : 24/03/2015 11:24 am
