Crank options - Rec...
[Closed] Crank options - Recommendations needed 🙂
[#2068009]
Morning Folks,
I am in need of a new chainset.
I currently have a Truvativ Firex Team. The external BB is on its way out and the better "upgrade" replacement options don't all seem Truvativ compatible.
Added to the fact that the chainset was a steal when I bought it means a replacement BB will in some case be more than I paid for the entire chainset 😡
So contemplating going the whole hog and replacing the lot.
Chainset will be for a Soul running all three rings.
I currently use a couple of Middleburn RS7 & RS8's but fancy sticking with the external BB jobies.
Any recommendations?
Any to avoid?
Posted : 08/10/2010 11:25 am
SLX. Steel middle and granny last for ages longer than alu rings. Lots of BB options too. The Shimano BB above deore are OK too. It's not bling though!
Posted : 08/10/2010 12:00 pm
Or also:
http://www.on-one.co.uk/i/q/CSFSVDMTB/fsa-a-v-drive-atb-chainset-megaexo
The chainrings are fairly good and you get a BB - That said FSA BB are no better or worse that shimano IMHO (make sure you check if you get all the o-rings if you buy it as that can seriously recude the longevity - I retrofitted mine).
Oh Bo11ox - out of stock 🙁 SLX then 🙂
Posted : 08/10/2010 12:04 pm
