Crank length
[Closed] Crank length
[#3458421]
Will I notice a big difference changing from 175 to 165mm?
I've got a low BB on my frame and as my timimg is crap I keep smacking my pedals. I'm thinking this might help a bit.
Posted : 13/12/2011 11:12 pm
 mboy
175 to 165 will be pretty obvious
175 to 170 less so, but will still improve your ground clearance, and it's surprising the difference 5mm will make.
Posted : 13/12/2011 11:19 pm
I tried exactly that to also get a little more clearance but I didn't like the (slightly) shorter stroke at all ! I'm only 5' 6" and always used to use 175's when I raced just about EVERY week. Read later that I should REALLY use 170's (which I switched to) then I read it should be 165's but, as I said - didn't suit. Now I've decided to go back to 175's as they just felt right ! There are NO real rules in cycling - just personal preferences I guess...
Posted : 13/12/2011 11:26 pm
i did that to gain more clearance - they felt short and like i couldn't get any power down.
i didn't like it.
Posted : 13/12/2011 11:28 pm
Thanks guys - Anyone selling their shorter cranks so I can give it ago?
Posted : 13/12/2011 11:30 pm
I can only add - on bikes that are subject to pedal strikes - ever few mm here and there adds up to an important log / rock that you miss (and maybe saves you a trip to A+E).
So what worked for me:
- shorter cranks
- more fork and shock pressure (not ideal)
- thinking ahead
- bigger tyres (think rubber queens)
- loose weight
- get a new frame
Ok - I never got as far as the last 2.
In answer to your opening Q- yes you will probably notice it. It might be better or worse for pedalling depending on what you're used to.
Posted : 13/12/2011 11:35 pm
I looking at this as well as increasing the fork length by 30mm so hopefully it will all make the bike better for me.
Posted : 13/12/2011 11:47 pm
If I go from my hardtail 170 cranks to my rigid 165 cranks and haven't ridden it for a while I notice the difference. The other way round I don't. My previous bike had 175 cranks which I found fine off road but if I rode for a few miles on the road where I wasn't moving around on the bike then my knees didn't like it. Given the choice I'd probably stick with 165 as I prefer to spin rather than grind but the choices in 165 are limited.
Posted : 14/12/2011 2:22 pm
I use 170mm cranks (previously used 175mm) - probably in my head but I tend to spin a fairly high cadence and they seem to suit that.
Not sure about reduced power, I think that's just my legs 🙄
Posted : 14/12/2011 2:37 pm
I swapped to 170mm (from 175) on one of my bikes purely to avoid pedal strikes. It worked brilliantly and I really don't notice the difference when pedalling.
Posted : 14/12/2011 2:40 pm
Use 175s, 170s and 165s on three different bikes. 165s are very short and noticeably harder to turn compared to 175s but clearance is immense.
170s on a HT are a reasonable compromise but still harder work than 175s.
Posted : 14/12/2011 2:47 pm
