Crank Help!!!
[Closed] Crank Help!!!
[#2263510]
Im building a trail/XC hardtail machine which will be used for both riding round places like Cannock and also small flat country parks with the family from time to time.
I was looking for a double with bash and guide but im not sure why other than i think they look cool - im new to trail biking and not to sure on which crank/chainsets are best for what purposes.
Iv got a Kinesis XC120 frame with Sram X9 comps so far ( shifter and rear mech ), and only really wanna pay around the £150 mark new or second hand.
any1 got a preference?
Posted : 08/12/2010 9:06 am
I would pot a triple on until you know your preference for gearing. I run double and bash 36 and 22 rings but others find very different combinations suit their riding style
Posted : 08/12/2010 9:09 am
What sort of riding do you do - i come from road biking which is a 34/50 double so i was worried a triple would be wasted? 😕
Posted : 08/12/2010 10:19 am
Go for a triple unless you plan on whacking the crankset into logs and rocks at every opportunity.
Posted : 08/12/2010 10:26 am
SLX, looks decent fits your budget and comes with either double and bash or triple, the triple would come in handy for the flat country park riding.
Posted : 08/12/2010 10:36 am
Exactly that
Posted : 08/12/2010 10:55 am
thanks guys - was looking at the SLX but wasnt sure if it would work as well with the Sram stuff so was looking for a truv comparison!! so i can mix shimano and sram?
was also looking at the FSA gravity sets - again probably more on looks - lol what a girl ha
Posted : 08/12/2010 10:58 am
[i]i can mix shimano and sram?[/i]
yes although shifters and rear mechs need to be same company as they have different cable pull. Evrything else 9 speed is compatable (chains,casettes, cranks).
Posted : 08/12/2010 11:03 am
Shimano rear shifters and rear mechs aren't compatible with Sram rear shifters and mechs but you can use Sram shifters with Shimano front mechs (Sram front mechs are goping!).
In terms of chain rings, cassettes and chains mixing Sram and Shimano is fine so long as it's all the same speed. Most people go for Sram chains and Shimano cassettes. Truvativ chainsets tend to be a bit heavier I think and their BBs aren't much cop.
Posted : 08/12/2010 11:05 am
Worth noting you can cheaply and easily convert a triple slx to double but a double slx needs some butchering to convert to a triple,
Cost me about £35 to convert a triple slx to a double with a chain device, eg, 36t deore middle ring, fsa bash and a blackspire stinger from crc, and I was left with a spare middle and outer ring, but the chainring tabs on a double slx need fileing down a bit to fit triple rings as well as buying the rings
+ whatever it is now for slx. Apparently there is only 20-somehting grams in wieght difference with more expensive xt. And it looks nicer if that's a consideration for you.
Posted : 08/12/2010 12:13 pm
Seems like most think the SLX is best better for the money then? im suprised that there isnt more competition for shimano these days in this price point 🙁
Posted : 08/12/2010 12:34 pm
