Crank Brothers Mult...
[Closed] Crank Brothers Multi 17?
[#2119328]
Looking at getting another multi tool, as a spare and for my roadie saddle bag, I currently have a Topeak Alien which is great but I'm after a slightly smaller one in size, and I like the look of the CB 17, anyone got one, what are they like to use/live with and are there any alternatives?
Cheers in advance
Posted : 24/10/2010 7:18 am
I had it and it's a very good multitool, has everything You need. Good quality and well made, the chain tool is quite ok as well, only the spoke key isn't anything special and I never actually used it. Very good for MTB as it has a torx there, the screwdrivers could be a bit longer, but again for a quick fix/tune up it was perfect. Looks ok as well, not too big, enough tools. Gave it to a friend who started cycling again.
I now have a Topeak Hexus with detachable reinforced tyre levers, similar size also well made, good chain tool, better than on the CB 17. I would recommend anyone of those two.
Also CB has the tightening bolts for a 3 or 4mm allen key to adjust how easy it will fold out, but to adjust it You need a separate allen key. Topeak has a 4mm allen key in the tools and also on one of the levers, upside is You can use it to tighten the tool, use it on the chain tool etc, but if You loose one of the levers than You won't be able to use the chain tool without a separate 4mm allen key.
Posted : 24/10/2010 7:32 am
Had a CB17 for 6 or more years, works well IMO & has lasted well to. My only minor gripe with it (& most multi-tools of this type) is occasionally you come across a bolt which you can't reach with the stubby Allen keys (eg front mech clamps on FS bikes).
Posted : 24/10/2010 8:52 am
I have, and rate, a CB17. However, I'd actually recommend the CB19 which has one extra tool and comes in a case which might help keep water off the tool and so stop it (eventually) rusting.
Posted : 24/10/2010 10:57 am
I had a 19 (I think)
worked v well
only gripe is that some bastard nicked it when I left a bag unattended on the prom nr Bournemouth once
Posted : 24/10/2010 11:02 am
Lost my original one. Got the new version, which doesn't seem so keen to rust.
Posted : 24/10/2010 11:08 am
I got the 19, very good. Use the spoke key for building wheels and haven't had any problems
Posted : 24/10/2010 11:10 am
Had mine for about 5yrs. Still works well, as it always has. The tools are a little short but more than adequate for trailside repairs. It just feels really well made, and I'll definitely be getting another if I lose this one.
Posted : 24/10/2010 11:49 am
Very happy with mine…but just discovered that the chain tool (on the older model) does not quite work on a new Shinano 10 speed MTB chain. It does not push the pin through enough on the skinny chain before the tool bottoms out. Found out the hard way in a race and ended up finding a rock crystal, shoving it in at the end of the pin and using the extra length it provided to get the damaged bit of chain apart - McGyver watch out... Reassembly is OK though!
Posted : 24/10/2010 12:11 pm
