Crank brothers iodi...
[Closed] Crank brothers iodine 2 help
[#6092778]
Got a new frame with 142 rear end does anybody know if I can convert from qr to 12mm ? Seems to be the bolt holding the free hub on is the problem can I just get a different free hub or not please help cheers
Posted : 05/04/2014 6:42 am
If the caps don't come off, then it's a QR rear axle only and cannot be converted. I had the same issue with my iodine 3 wheels, I ended up selling them and buying another set of 142x12
When 2 pure when cranks bros importers I did look into changing the rear axle and was quoted I think £150 if done by them. They wouldn't sell me the axle. But I don't think the new importers will do this for you as they still have very little stock.
Posted : 05/04/2014 7:39 am
Long shot but I've got a 142x12 converter to let you run a 135x10 rear wheel in a 142x12 frame
It's from a 2013 zesty
Posted : 05/04/2014 7:41 am
Pretty sure the hubs are 142 specific, I bought a set with 142 and can convert down.
When I got my iodine 3 the guy told me it was iodine 3's only and you need to get them set up already.
But give 2pure a ring to check tough.
Posted : 05/04/2014 8:05 am
Cheers for the help guys looks like I'll move them on
Posted : 05/04/2014 8:10 am
IIRC the 2014 wheels are convertible by swapping end caps; I didn't think the previous wheels were but unhelpfully there aren't any immediately obvious tech docs for these on the CB website.
Posted : 05/04/2014 8:42 am
