Could you measure a...
[Closed] Could you measure a 27.5 wheel for me?
 Leku
[#6884402]
Including tyre. From ground to top of tyre please. And state what type and size of tyre it is...
That would be much appreciated..
Posted : 23/02/2015 7:23 pm
Posted : 23/02/2015 7:31 pm
 Leku
Thanks qwerty. I was hoping to get a couple of real world measurements.
Particularly interested in Hans Damf 2.35 and High Rollers.
Posted : 23/02/2015 7:34 pm
Minion 27.75
Ardent race 27.5
Both on Stan's arches
Posted : 23/02/2015 7:43 pm
Stans Arch Ex with Bontrager XR4. 27.75
Posted : 23/02/2015 7:56 pm
 Leku
mmm 26" Crest with 2.35 Hans Damf 26.5"
So generally just over an inch difference to diameter.
Posted : 23/02/2015 8:28 pm
 br
[i]So generally just over an inch difference to diameter. [/i]
Which you'd expect, as they are only 25mm greater on the diameter - so you need 12.5mm extra clearance under the fork arch.
Posted : 23/02/2015 9:22 pm
I did think briefly about the possibility of fitting 27.5 wheels to my Patriot. However it'd only raise it off the ground, and tha wouldn't be any good.
Posted : 23/02/2015 9:25 pm
27.75' Conti MK2 on DT XM1501 23mm inner rim width
Posted : 23/02/2015 10:10 pm
HD 2.35 - 70cm
Magic mary - 71cm
On flow ex, tubeless (so a bit less air in them).
Give or take a few mm
Posted : 23/02/2015 10:21 pm
My wheels are 27.75 inches with 2.35 Maxxis HR 2 tyres (Flow EX 650b rims)
Posted : 23/02/2015 11:16 pm
