Could I make a 69er...
[Closed] Could I make a 69er out of a ...
[#2100927]
My Surly 1x1? The axle to crown of my 1x1 rigids is 453mm, of my Reba 100mm 473mm. So if I was to swap for a set of Karate monkey forks (468mm A to C) and a big wheel what would be the likely down sides or issue? I guess slacker angles and maybe a slight issue on ups, but surely not to much more than with the Rebas? Ok and yeah the other downside would be that it would look daft...
Posted : 18/10/2010 9:28 pm
Come on... Not even a clown bike related insult?
Posted : 18/10/2010 10:17 pm
I've done much the same with a scandal
Posted : 18/10/2010 10:20 pm
Or, Cheap 69er frame on classifieds just now....
Posted : 18/10/2010 10:27 pm
you dont need to swap out your forks, a 29" wheel will fir in your 1x1 fork with room to spare, so youll only raise the front by about 30mm due to increase in wheel size.
Posted : 18/10/2010 10:33 pm
oh, didn't read carefully enough - agree with stato, you're prob ok with current fork
Posted : 18/10/2010 10:34 pm
 Sam
Or ideally you'd go for a bit shorter fork with a greater amount of offset to help keep the steering sharp.
Posted : 18/10/2010 10:58 pm
I did a similar thing with my 456SS a while ago. 26" On-One fork with the regular 29er wheel. Fun but confused the Irish no end 😀
Posted : 18/10/2010 11:05 pm
