Cotic Soul & Do...
[Closed] Cotic Soul & Double ring set up...
[#6270309]
Just about to bite the bullet and go 10speed. Guessing a 26 granny will be a bit tight. Is 24/38 11-36 what most go for?
I think 1x10 is going to be a bit limiting for me, when I want to open it up a bit on faster tracks.
Posted : 14/06/2014 6:51 pm
the last version i got up close to was pre dropper post et al, but the two up front wasnt an option, 36t was within mills of the chainstay, 22.32.44 eventually
Posted : 14/06/2014 6:56 pm
I ran 38/24 no worries...think you can get away with 26 tbh (mk3)
Posted : 14/06/2014 7:02 pm
 jruk
I've got a mk2 and run 11/42 x 36. It's an xt cassette + one up with a rf nw on the front. Shifting isn't perfect but it's better than a dropped chain and sore knees.
Edit: cranks are slx triple with short ring bolts.
Posted : 14/06/2014 7:26 pm
Do you mean will a 26T granny fit on a Soul frame? If so, yes it should fit fine. I have a 28/40T double XT on my Mk3, no problems in over a year. I ran 26/36 on a triple chainset on a Mk 2 frame for 18 months too, I did get a bit of chainsuck on that but I think that was more to do with the drivetrain components than the frame, it went away when I replaced the old bits.
Posted : 14/06/2014 8:20 pm
I have a MK3 soul and 40/26 rings on XT triple cranks with no clearance problems.
Posted : 14/06/2014 9:25 pm
I was told by Cotic that my Mk1 Soul will not accept a Shimano double, but Sram may just squeeze in due to the chain line or something....I stopped listening and started saving for a Solaris at that point!
Posted : 14/06/2014 9:33 pm
I've got a SLX M675 double chainset on the way for my MK2 soul. The chainrings will be swapped for a N/W raceface ring (34t). Am I likely to have problems??
Posted : 14/06/2014 9:38 pm
Should be fine I think. The new ring will be fitted where the outer ring was, if I've understood what you're doing correctly? The old ring would have been much bigger than 34T, and should have fitted fine, so don't see how the new one could cause a problem.
Posted : 14/06/2014 9:43 pm
Mines a mk3, just emailed Cy to see if a 26/38 is possible.
Posted : 14/06/2014 11:36 pm
Polisher man see my above post.
Posted : 14/06/2014 11:43 pm
Also a mk3 with 24/38 xt double here and no issues
Posted : 15/06/2014 12:42 am
