Cotic Solaris Reach
[Closed] Cotic Solaris Reach
[#6417809]
Does anyone know what the reach and wheelbase figure for a large Cotic Solaris is? I have searched everywhere but can't find anything on it!
Posted : 15/08/2014 10:05 pm
I had the same question for a soul. I emailed Cotic and they sent the figures back. Sure they would do the same for you for the Solaris if you ask
Posted : 15/08/2014 10:42 pm
 jimw
I'll check mine in the morning if no one comes up with a measurement in the meantime.
Just to be clear, by reach you mean horizontal distance between a vertical line from bb centre to centre of the upper head tube?
Posted : 15/08/2014 10:43 pm
Thanks! Yes that's the figure I am after, I want a full sus 29er that is a similar size to my L Solaris, but I'm not at home to measure my frame.
Posted : 15/08/2014 10:54 pm
If it's full sus, with the same reach, and without steeper angles, it'll probably have a longer wheelbase. And you probably want slacker angles on a full sus… so don't try and aim for the same wheelbase… in fact, just ignore that figure… stick with reach etc.
Posted : 15/08/2014 11:27 pm
From memory it's circa 630mm.
Posted : 15/08/2014 11:30 pm
Hmm… Solaris product page could really do with reach and stack measurements on it. [b]noted[/b]
Posted : 15/08/2014 11:32 pm
It gives effective tt length. That's measured from centre line of ht to centre line of seat post. 624mm
Posted : 15/08/2014 11:35 pm
Thanks Kelvin, I like fit of my Solaris, especially the space or reach I have along the top tube so I'm looking for a bike with similar TT and reach figures to the Solaris. I would be perfectly happy with a slacker head angle and a bit more travel too!
Posted : 16/08/2014 8:27 am
Though reach lengthens as a hardtail sags under fork load, whereas it's mostly constant on an FS model.
Posted : 16/08/2014 8:34 am
 jimw
Just measured my Cotic.
Wheelbase with 100mm rebas is 1130 mm
Reach, after a number of slightly different measurements (!) is about 422-25mm
Hope that helps
Posted : 16/08/2014 10:39 am
Perhaps reach should always be measured when sagged then Brant. Unloaded geom on a hardtail is always a pretty hopeless guide to riding position, or anything really, for the reason you mention.
Posted : 16/08/2014 3:12 pm
http://www.shedfire.com/2014/07/14/i-should-probably-do-some-diagrams-for-this-but-quickly/
Posted : 16/08/2014 3:21 pm
how the heck are we supposed to measure 'sagged' reach?
Posted : 16/08/2014 3:23 pm
ahwiles - Member
POSTED 14 MINUTES AGO # REPORT-POST
Same way you measure reach. Except you sit on the bike and a friend helps you.
Posted : 16/08/2014 3:38 pm
Thanks for that, looks like a Large Codeine may be quite a good fit.......
Posted : 16/08/2014 9:01 pm
