Cotic Soda forks
[Closed] Cotic Soda forks
[#4097586]
I have just bought a cotic Ti frame. Any suggestions for forks that work well with sofa/soul frame?
Graeme
Posted : 24/06/2012 9:39 am
bump
Posted : 24/06/2012 8:01 pm
Found mine by far the best with 100mm rebas.
Posted : 24/06/2012 8:06 pm
I run mine with Fox F120 forks, very nice with those.
I also have a Soul, have tried it with 100mm, 120mm and 140mm and much prefer it with the 120mm setup (its a 2007 so a bit different geometry to the newer ones).
Posted : 24/06/2012 8:47 pm
Depends on the age. Up to 2008/9, try some 130mm Revelations with U-turn to give you the full option from 100-130mm; after that, perhaps 120mm Rebas.
Posted : 24/06/2012 9:06 pm
personally id second Fox F120's QR15
Posted : 24/06/2012 9:07 pm
Something like a bolt-thru Float 120 would make sense - fairly light, fairly stiff, 120mm. Or Revelations. All the Souls, Sodas and BFes have identical geometry for a given size, regardless of era.
Posted : 24/06/2012 9:15 pm
The old 100-130mm quick release Revelations went perfect with my Soul- light, controlled, perfect range of lengths... I always liked it best at 120mm or thereabouts but it worked really well at all the lengths, just had a different character. (u-turn much better for this sort of thing than TALAS, fork works correctly at all lengths)
Posted : 24/06/2012 9:22 pm
I ran a set of TALAS so I could swap between 100 and 120 (but most of the time ran at 100).
The last time I rode it I was finding it a little skittish on the descents at 100 so upped to 120 and it felt much better. But this was immediately after riding a couple of slack bikes.
I run F120's on the Soul and have no complaints...
Posted : 24/06/2012 9:23 pm
The setup on the old Soul's was more suited to a 100 - 120mm fork. I bought a second hand earlier this year and spoke with Cotic about it before putting forks onto it. (perhaps I used the wrong terminology saying the geometry was different)
As for the Soda, you could run it with 130 - 140mm I guess but I think the handling would be pretty poor, also Cy recommends 100 - 120mm with the Soda.
For me the bolt through Fox F120 (or Reba/SID equivalent) with a nice wheelset is perfect on the Soda.
Going back to the OP, I am sure you will love it with 100 or 120mm forks, its a brilliant frame to build around.
Posted : 25/06/2012 11:19 am
The new frames are stiffer than the old ones so they suffer less (in terms of unwanted flex) from the extra leverage from a longer stiffer fork.
Posted : 25/06/2012 11:46 am
Well happy with Fox F120/QR15 on mine.
Posted : 25/06/2012 1:14 pm
Hi all,
Thanks for the feedback!
Very useful.
I wanted to canvas opinion before "forking" out for forks!
I quite like the Talas 100-120 option.
Posted : 26/06/2012 2:40 pm
120mm bolt through Reba on mine.
Posted : 26/06/2012 3:27 pm
Hmm, I have a set of 09/10? TALAS which just came off the Soda sitting around doing nothing...
They are 9mm QRs though...
Posted : 26/06/2012 3:55 pm
Metalheart,
Send me some photos and details to J_RobbATskyDOTcom
I may well be interested.
Posted : 26/06/2012 4:33 pm
