Before ordering I just wanted to confirm these are the correct brake mounts, they are going on a Nomad 4 which states 180mm post mount to post mount.
I am running 180mm rotors & Guide RS brakes:
Thanks
Bump 🙂
Think your question is a little ambiguous, but if we're talking rear brake and your Nomad frame takes a 160mm rotor without any adapters then a +20mm post to post adapter is right for you. The added complication being that SRAM (I think) use a slightly different adapter which has the caliper more inline, where the Hope ones shift the caliper along a little. Might make a different, might not. I only tried it the other way, Hope brake on SRAM adapter and the caliper fouled the adapter.
Sorry, not a great help in the end.
More like this one [url= https://www.evanscycles.com/avid-cps-160mm-rear-180mm-front-post-mount-adaptor-EV157270 ]AVID / SRAM Adapter[/url]
Also, this may or may not be useful - [url= http://www.sram.com.cn/sites/default/files/techdocs/95-5018-000-000_rev_b_disc_brake_caliper_mounting.pdf ]SRAM BRAKING PDF[/url]
