Currently have a 90mm stem on my Roadrat, with a 25.4mm flat bar on it. Planning to change to drops, probably the on-one Mary - will I need a longer stem?
Have the 130mm that came on the roadrat somewhere - but it's a 31.8 clamp, so the Mary bars will need to be bought to suit one stem or the other - any advice?
You'll need a shorter stem if running drops.
Mary is a sweep bar not a drop bar though? I run inverted Marys on my medium long 'rat and went from the long one to a 90mm.
I think you are getting confused with Midge bars
What if said, and if they are Marys, no need for new stem generally.
Cool. I've not used drops since I was a teenager on a road bike, so the Marys are a toe in the water. They're cheap, at least - I might end up with a different set in time.
marys not a drop bar?
Midge, I meant, not Mary. Sorry, new ground for me.
