Converting CK 15mm ...
[Closed] Converting CK 15mm front hub to 20mm
[#8031510]
Just because my google fu is weak today (like the rest of me then.....) can I convert my Chris King 15mm front hub to 20mm and where can I get the parts to do it?
Cheers guys.
Posted : 02/09/2016 1:14 pm
th ld hub you can convert to 20mm with a new axle kit. the sd ( small dia) hub, no can do. Only 15mm axle fits the sd hub
Posted : 02/09/2016 1:32 pm
I'm in luck then, as it's the ld I have.
Now to track down a 20mm conversion kit.....
Posted : 02/09/2016 1:39 pm
got mine from leisure lakes
Posted : 02/09/2016 1:45 pm
 P20
Think I got my last one from aspirevelotech
Posted : 02/09/2016 1:58 pm
I've just bought a used one on ebay - must be my lucky day for a change!
Thanks, Andy.
Posted : 02/09/2016 2:01 pm
Andy R...is your LD first gen (serial 171...) or 2nd gen (serial 172...) If is the 171 then do you feel like selling me your 15mm axle? 🙂
Posted : 02/09/2016 5:34 pm
It's the first generation but I think I'll probably keep the 15mm axle, just in case I want to go back to using Fox or something rather than Marzocchi.
Posted : 02/09/2016 9:47 pm
