Converting a 150mm ...
[Closed] Converting a 150mm Revelation to 130mm
[#4256467]
Hey Peeps - just bought myself a Rockshox Revelation from Merlin and want to convert it from 150mm to 130mm as would suit my bikes geometry better. I've heard its possible and isn't too difficult to do but can't find any "instructions" - can anyone point me in the right direction? thx a million
Posted : 14/08/2012 7:02 am
Go here http://m.bikeradar.com/gear/article/workshop-how-to-adjust-travel-on-a-rockshox-trail-fork--26840/ and all will be revealed
Posted : 14/08/2012 7:13 am
Revelation Technical Manual 2011:
I converted my 140mm to 150mm by taking out the spacer. However, you will need to add two spacers which you may not of got with the OEM forks from merlin.
Posted : 14/08/2012 2:07 pm
Undo bottom nuts not all the way
hit with hammer
pull lowers off + drain
clean lowers and stanch
remove circlip in left leg
pull air spring out
pull off end cap
add two spacers
lube
replace end cap
push spring into left leg
put circlip on
put 5ml 15wt into lowers
push uppers into lowers
screw in
profit
Posted : 14/08/2012 2:14 pm
