Connecting brakes (...
[Closed] Connecting brakes (Shimano Dual Control)
[#4461882]
Hi,
I am one of the freaks who likes Dual Control brakes.
I was thinking of trying to connect up a spare set of dual control levers, similar to these :[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=7888 ]Dual Control LX Brakes[/url]
to some of these:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=67226 ]Deore Brake Calipers[/url]
The original lever set cost something like £15 for the pair and I have dual control on my other bike. These are for a 5 inch full suss.
What bits do I need to connect the two together? Would Goodridge hoses be best, or should I try and use the Shimano ones:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=14854 ]Brake Hoses from Shimano[/url]
No idea if they are standard. All seems to be a tad complicated for me.
Posted : 15/10/2012 11:45 pm
Bump for the lunch time crowd.
Posted : 16/10/2012 1:12 pm
gribble,
The levers and callipers are compatible without any issues.
You need the hose with straight connectors both ends...your 3rd link is to a hose with 1 banjo and 1 straight (some old XT/XTR models) connectors and will not work.
This is the correct hose:
http://www.ebay.co.uk/itm/Shimano-M525-535-Deore-Disc-Brake-Hose-Front-Black-Front-/160886811022?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item257599e98e
I prefer real Shimano tango orange brake fluid, but you can use cheapo LHM fluid at a push, although it may thicken with unpleasant results in very cold weather.
PaulD
Posted : 16/10/2012 1:38 pm
PAul D, many thanks, that is really helpful.
Posted : 16/10/2012 10:40 pm
Castrol lhm is fine, would you only put audi brake fluid in your car?
Posted : 16/10/2012 10:57 pm
